Vand OBD II
Pentru BMW E30 E36 E39 Z3 X5 din 1982 pana in 2001. Produsul este nou, nefolosit. Am 2 bucati.
Usage:
With the ignition OFF connect the tool to the 20 pin port
Turn the ignition ON so the dash is lit up but the engine is not running
Press and hold the button for 10 seconds, for the light you want to reset
Release button, turn ignition OFF and disconnect the tool
Start engine and your light will now be reset
NOTE: On some dashboards there is needed to make a inspection reset before a oil reset
100 Ron negociabil. Accept doar plata in avans, transportul prin posta romana il suport eu.
0747 554 789
Edited by dannye36
