Stire traznet
sexybeast330d
tocmai ai citit un articol legat de o generatie noua de motoare de la BMW
eu personal sunt fan diesel si noul motor de 2000cm diesel va veni in 3 trepte de putere:
143hp , 177hp si tineti-va bine vedeta suprema Variable Twin-Turbo 204hp !!!!!
mai zic o data ca mie abia imi vine sa cred 204hp din 2000cm diesel in 4 cilindrii
citez mai jos din articol:
BMW’s new four-cylinder diesels displace 2.0 litres cubic capacity and come in three power and performance stages: Both the “basic” model developing 105 kW/143 hp maximum output and the 130 kW/177 hp version come with a turbocharger featuring variable turbine geometry for superior power and performance. The most powerful version of the new engine also boasts Variable Twin Turbo technology already lauded in BMW’s six-cylinder diesel models. This technology also referred to as multistage turbocharging gives the 2.0-litre power unit maximum output of 150 kW/204 hp, making this the first all-aluminium diesel engine in the world to develop output of more than 100 hp per litre
aici e linkul unde gasiti tot articolul ... eu deja m-am indragostit a doua oara de marca asta
http://www.worldcarfans.com/news.cfm/count...amics-in-detail
tre sa imi revin dupa atata putere javascript:emoticon(':P')
smilie
Edited by theotien
Este vorba de 123d cu 201 cp sigur va intra in productie cat de curand si cred ca mai vin surprize din astea oricum BMW schimba din toamna mai toate motoarele chiar recent aparute si denumirile si codurile si din 2.0 poti sa scoti si mai mult decat 200 cp,dar asta e o alta poveste si nu vreau sa o mai discut odata.
