Eonon D5150 gps + europe map?
TheSorcererX
poate te ajuta asta :D
in functie de ce e mai jos poti cauta harti pe google sau torrente, in cazul in care nu iti da cineva copia dupa card :D
link de unde am copiat informatia: https://www.farcebook.com/note.php?note_id=392570370530
What other maps can be used in Eonon, and how to make it?
7 January 2010 at 09:39
Many people who own Eonon GPS are not clear that except our built in map, what other map software can be used in our unit, now we would like to introduce to you. Until now, we know the following maps can be used in Eonon: POLNAV, IGO, Tomtom.
G2201G2201
1. POLNAV is the built in Eonon map. We use the latest legal edition of POLNAV map! Different from other no brand GPS, we are using the legal map! It's the latest legal edition from POLNAV.
2. IGO is another map which can also be used in Eonon.
Here this link in our Eonon forum shared by our customer Xperiat, he told us how to run iGo8 Navigation Software in our GPS: http://forum.eonon.com/Default.aspx?g=posts&t=1007
Quoted from his experience:
"I was able to install the iGo8 Navigation software from Navngo! Also loaded up Caifornia Maps and am using this awesome GPS Navigation software. It's muc better than Smart2Go in my opinion and has tons of options!! PM me if anyone wants it and wants to give it a shot. I was also able to run TomTom 5.2 but Maps were inaccessible as the software expects them to be in the My Documents folder. So, I accessed the WinCe shell by getting to explorer (contact me for exact steps) and now my PNA is aso a PDA! How awesome is that?? So, now I boot into a Windows CE desktop interface and can launch my iGo GPS Navigation software from within (using a shortcut)."
"The unit runs WinCE 4.2 and the version of iGo8 that I have is for PDAs, PNAs and WinCe4.2 and up devices. All one has to do is install the application to the root of the 2GB SD card and add the appropriate line i the YFAUTORUN.INI file. I have mine as \SDMMC\iGO8\iGO8.exe this instructs the Navigation Startup Screen to point to iGo8.exe in the iGo8 folder n the SD card. That's it...it loads up, discovers the GPS satellites and off you go! I have the California Maps, POIs and all the 3D Terrains loaded up and working well. Its fast and looks fantastic too. If you need the files (softwae + maps + POIs) then I can upload them somewhere (let me know where)...they're close to 1.8GB in size. Also, if you have the YAUTORUN.ini saved with the text "\explorer.exe" then it loads the WinCE 4.2 shell...the complete Windows CE UI with complete navigation, file explorer, one can run programs off the SD Card etc."
E1025E1025
3. Tomtom can be also used in Eonon! Shared by one customer who posted here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=63829
"Here is how I made "Tomtom" work on my eonon GPS unit with "SD card Mapping" that displays on the DVD unit.You can easily do this too! First I assume you own a licenced version of "Tomtom 6" second copy and save the files currently on the SD card to a safe folder on your pc (just incase you cock-up).Now format the sd card and create a folder on it naming it exactly like this ( MobileNavigator ) open this folder and also the folder on you pc that contains your copy of tomtom6. Copy and paste the files from tomtom6 into the folder "MobileNavigator" on the sd card." Are you still with me?" OK. Now locate the tomtom.exe file (Two red hands) and rename it "MobileNavigator.exe" when you have done this close the folder finaly go to the saved original software on your pc and you will find two very small files named 1.YFAUTORUN.INF and 2.autorun.inf copy and paste these two onto the sd card.Power off the gps unit fit SD card and power on. Bingo! it works well for me.
Settings you may need in tomtom. The gps receiver now needs to be set,to do this.....
Run the software,Tap screen and select " change preferences " find the icon " show GPS status" select this.Tap configure.Scrole forward to choose "Other NMEA GPS receiver" and select Set GPS Baud rate to " 9600" and click done.Select "Com one".Click done!
And that's it!"
Hope their experience is useful to you! That's so called community spirit! You can get happiness by sharig and helping others! Let's move on!
  • 7 months later...
Salut, am cumparat si eu Eonon d5150 l-am instalat si pare sa mearga mai tot doar ca nu reusesc sa dau de capat cu backlight(lumina de la butoane), nu stiu unde trebuie conectat firul si nici nu gasesc o solutie pe net asa ca rog pe cei care au mai instalat aceasta unitate sa imi dea o mana de ajutor.Backlight ar trebui cumva conectat la sistemul de ilumintare dar unde am eu asa ceva la navi ,ori e prea evident si nu vad ori sunt prea nepriceput. Multumesc anticipat pentru ajutor.
  • 8 months later...
