intrebare 320d e90 facelift
Salut! imi cer scuze daca nu postez unde trebuie, am cautat si nu am gasit exact ce voiam.
VReau sa imi cumpar un 320d e90 intre 2009 si 2011.
as vrea sa stiu doar din punctul de vedere al fiabilitatii care este diferenta intre modelul 163 177 si 184 cp.
pe net am gasit doar ca cele 2007-2009 au probleme cu distributia, dar banuiesc ca la facelift s-au schimbat?
318d-143cp e ok? la fel, doar de fiabilitate intreb
mersi mult!
p.s de asemenea, daca are cineva la vanzare vreunu dintre modele, m-as bucura sa-l scap de el
http://forum.bmw5.co.uk/topic/83586-n47-timing-chain-issue-highlighted-on-watchdog-relevant-to-f10/
Current Car:2012 F10 520d SE Auto
Mine made no noises, and then went bang, bear in mind that was after the timing chain had been repaired by BMW and the Crankshaft then decided to give up. The crankshaft isn't completely fault free after talking to a BMW Tech the other day.
