BMW recommends Shell
sbircris
E bine ca au renuntat la Castrol, cel putin dpdv al contrafacerii! La noi cel putin Shell-ul nu cred ca-i chiar atat de utilizat! Asadar, o sa le ia ceva timp la "fakeri" sa faca noul tip de ulei BMW Made by Shell! Cu siguranta uleiul in sine va fi acelasi, doar ca trebuie sa copieze bidoanele si etichetele! Sau poate ma insel eu si chiar se vor misca rapid a.i. sa le plaseze pe piata!
  • Downvote 2
Bidoanele nu sunt la fel, ce am prezentat eu este bidonul de pe site-ul Shell. Diferenta de pret e prea mare, este sub 50% din pretul celui prezentat de mine, eu nu as lua de pe ebay.
Te inseli
pretul online este cel mai mic
eu comand mereu de pe ebay shell si motul ptr ca nu are adaosuri si gasesti cu transport gratuit chiar
Din ianuarie 2015, BMW toarnă in motoare ulei Shell.
http://www.enginebui...upplier-choice/
The BMW 5W30 motor oil is the factory engine oil approved for almost all BMW engines, except for BMW Diesel and some M3/M5/M6 engines. It's the only oil approved in the US for BMW's turbo N20 N54 N55 engines, including the S55 engine in the 2015+ F80 M3/F82 M4. It can also be used in most MINI engines.
This oil was especially formulated for the USA market to meet compatibility requirements with the high sulfer content in our fuels. It meets BMW LL01 and API SL specs for gasoline engines from 1997 up through today as well as ACEA A3/B3 requirements. This is the current oil used in BMW dealerships.
Edited by claudiuBWR
Pfff, urat
