Resetat calc de bord
LiviutzP
Cauta pe forum ca sunt multe thread-uri deschise pe tema asta :blink:
No need for reset tool for 2001+ model
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
am un e46 din 99 stie cineva cum pot sa resetez ca din bord nu merge
223008[/snapback]
N U M A I cu tester merge.Cu altceva nimic.Daca ai mufa de diagnoza la bord.
Daca ai mufa rotunda de diagnoza la motor,e ok,o faci asa:
Pui un fir cu un cap in pinul 7 al mufei (e undeva spre exterior) si celalalt cap pe masa.(caroserie),deci pui pinul 7 al mufei de diagnoza la masa.APOI pui contactul stai 5 secunde,iei contactul,iei firul si gata!
Fiind masina ta din 99 e posibil sa ai mufa la motor!
Asa arata mufa!Eventual are capac!
