fire semnalizari e46
mb 316i
scuze, a fopst weekend + meci
A3 Light switching centre control unit
Connector location views
Number X-pin, colour Description
X12 54-pin, black Plug connector Light switching centre control unit
Pin assignments at plug connector X12
Pin Type Description / Signal type Connection /
Measuring notes
1 A Signal Rear left direction indicator Connector Rear left direction indicator
2 A Activation, right bi-xenon headlight Xenon headlight, right
3 A Signal, right auxiliary direction indicator light Front right auxiliary flasher unit
4 Not used
5 A Signal, left brake light Tail light, left
6 E Terminal 30 Fuse F106
7 A Signal, left low beam light Left low beam
8 A Signal, right high beam light Right high beam
9 A Interface, lights switching centre, trailer module Trailer module
10 A Signal Right brake light Connector Right brake light
11 A Signal, front right direction indicator Right front turn signal indicator
12 A Signal, left/right direction indicator switch Turn indicator/low beam switch
13 A Signal, high beam/headlight flasher switch Turn indicator/low beam switch
14 A Signal, rear load sensor Load sensor, headlight vertical aim control
15 E Terminal 15 Fuse F32
16 A Signal, centre brake light Centre brake light
17 A Signal, licence plate light Licence plate lights
18 A Signal, left auxiliary direction indicator light Front left auxiliary flasher unit
19 A Signal ground, front load sensor Load sensor, headlight vertical aim control
20 Not used
21 E/A K-bus signal K-bus connector
22 A Signal, front load sensor Load sensor, headlight vertical aim control
23 A Signal, +5 V front load sensor Load sensor, headlight vertical aim control
24 A Signal, hazard warning switch Hazard warning/central locking switch
25 E Brake light Connector Brake light
26 A Signal, +5 V rear load sensor Load sensor, headlight vertical aim control
27 E Terminal R Fuse F9
28 A Signal, fog light relay activation Fog light relay
29 A Outer right tail light Connector Outer right tail light
30 A Outer left tail light Connector Outer left tail light
31 M Ground Ground connector
32 M Ground Ground point
33 E Terminal 30 Fuse F107
34 A Signal, right low beam light Right low beam
35 A Signal, left high beam light Left high beam
36 A Activation, left bi-xenon headlight Xenon headlight, left
37 Not used
38 Not used
39 A Signal, headlight vertical aim control Q22 motor, left Actuator, headlight vertical aim control, left
40 A Signal, headlight vertical aim control Q11 motor, left Actuator, headlight vertical aim control, left
41 A Signal, headlight vertical aim control Q12 motor, left Actuator, headlight vertical aim control, left
42 A Signal, headlight vertical aim control Q21 motor, left Actuator, headlight vertical aim control, left
43 A Signal Rear right direction indicator Connector Rear right direction indicator
44 A Signal, front right parking light Right parking light
45 A Signal, front left parking light Left parking light
46 A Signal ground, rear load sensor Load sensor, headlight vertical aim control
47 A Signal Locator lighting Connector, instrument and locator lighting
48 A Signal, lamp in hazard warning switch Hazard warning/central locking switch
49 A Signal, rear fog light LHD: Boot lid lamp, left RHD: Boot lid lamp, right
50 A Signal, front left direction indicator Front left turn signal indicator
51 A Signal, headlight vertical aim control Q22 motor, right Actuator, headlight vertical aim control, right
52 A Signal, headlight vertical aim control Q11 motor, right Actuator, headlight vertical aim control, right
53 A Signal, headlight vertical aim control Q12 motor, right Actuator, headlight vertical aim control, right
54 A Signal, headlight vertical aim control Q21 motor, right Actuator, headlight vertical aim control, right
