Distributie sarita de la punct?
Acidutu
  On 8/6/2015 at 10:41 AM, E46 318i 2002 said:
4,25 Litri
pe subiect :
Service Repair Manual
Year 2001-2004
Engine code N42B20
Engine size 1995ccm
Power 105kw
Idle speed 650-750rpm
AT = 800-900rpm
Firing order 1-3-4-2
Spark plug Bosch FGR 7 DPQ
NGK BKR6EQUP
Denso K20TXR
Electrode gap (Bosch)1.6, (NGK)1.5, (Denso)1.0mm
Lambda 0.97-1.03
Radiator cap 2.0bar
Thermostat opens 105?
Battery 55Ah
Alternator 90A
Cylinder head tightening sequence
BMW 4 pistons Cylinder head tightening sequence
Cylinder head tightening torque 1 30Nm
Cylinder head tightening torque 2 90°
Cylinder head tightening torque 3 90°
Spark plug Tightening torque 28-30Nm
Engine oil with filter 4.25l
Cooling system 7.5l
Gearbox oil 1.0l
Automatic transmission fluid Fluid = 4.0l / Dry refill = 9.0l
Differential 1.0l
Engine oil grade BMW Longlife SAE 0W-30
BMW Longlife SAE 0W-40
BMW Longlife SAE 0W-50
BMW Longlife SAE 5W-30
BMW Longlife SAE 5W-40
BMW Longlife SAE 5W-50
Gearbox oil grade Orange label = ATF Dexron II D
Green label = Synthetic Mobil SCH630(BM) part No. 81-22-9-407-305
Yellow label = MTF-LT-1 / MTF-LT-2
No label = API GL-4 SAE 80
Automatic transmission fluid type ETL 7045E
Differential oil API GL-4 SAE 75W-90
Brake fluid DOT4
Wheel info eng
Tire dimension (x/y R z) 195/65 R15
205/55 R16
225/45 R17
Front wheel presure 1.9bar
Rear wheel presure 2.2bar
Wheel bolt tightening torque (B) 110-130Nm
Front hub tightening torque (H) 290Nm
Rear hub tightening torque (H) M22 = 200Nm
M24 = 250Nm
M27 = 300Nm
Brakes info
Minimal front brake disk thickness ® 20.4mm
Minimal rear brake disk thickness ® 17.4 / 8.4mm
Minimal front pad thickness (P) 3.0mm
Minimal rear pad thickness (P) 3.0mm
  • Like 3
  • Downvote 3
E90, 318i benzina, 2007.
Nu mai porneste nicicum, fara nici un simptom anterior. Invarte dar nu porneste.
Pe tester e totul ok, nici o eroare.
Mecanicul zice ca e posibil sa fie sarita distributia insa doar maine o va desface sa vada exact.
Daca astea or fi simptome legate de ditributie "slabita", parca se auzea zornaitul lantului in mers, daca acceleram mai putin decat ar fi trebuit , adica atunci cand masina mergea din inertie. Iar cu motorul neincalzit, imediat dupa pornire, daca nu accelerez mai puternic la plecarea de pe loc, are o trepidatie pe care eu o puneam pe seama ambreiajului.
PS: distributia a fost schimbata la 80 si ceva de mii de km la BMW Timisoara (BanatCar). Acum masina are 108.500 km.
Edited by cosmin.m
  • 8 months later...
  On 7/26/2015 at 1:34 PM, Service Premium said:
Daca a sarit de la punct, nu mai ai ce sa verifici. Se schimba obligatoriu kit-ul de distributie. Orice altceva e carpeala.
Poti schimba doar intinzatorul cand iti dai seama ca e uzat inainte sa sara de la punct.
Salut Service Premium
Am un BMW 318 E90 benzina si cred ca e sarita distributia de la punct, cum pot sa iau legatura cu tine?
Mersi!
