ACCELERARE E36 320I 24 V
MISU
MA DISPERA PROBLEMA DE CEVA TIMP ASA CA VA ROG CAT MAI MULTE IDEI.
CAND ACCELEREZ VINE IN NAS , PARCA NU SE ALIMENTEAZA PTR 2-3 SECUNDE DUPA CARE PLEACA NORMAL SI TRAGE BINE PANA PE LA 4000-45000 DE TURE DUPA CARE TREBUIE SA SCHIMB TREAPTA DE VITEZ PTR. CA IAR VINE IN NAS.
AM SCHIMBAT DEBITMETRUL ( SH ) , LA FEL , AM SCHIMBAT POMPA DE BENZINA (SH ) , LA FEL. DEASEMNENEA BUJII OK , FILTRU BENZINA OK. SIMT CA O IAU RAZNA.PLUS DOUA TESTERE FARA ERORI. SI NU VA PUTETI INCHIPUI CE AIUREA E IN DEPASIRI CAND TE REPEZI IN EA SI PANA- SI DA DRUMUL TE APUCA NERVII.
ORICE SFAT E BINEVENIT. (320I , 24 V , 1991 , 150 CP ). MERCI MULT.
@mishu, in primul rand bine ai venit...
In al doilea rand..eu cred ca-ti trage aer fals pe undeva printre debitmetru si clapeta de acceleratie...sau poti sa faci un test al injectoarelor...la bosch, e 20ron/injector...e posibil sa ai debitul prea mare la injectoare....adica injectoarele uzate :blink:
229722[/snapback]
INJECTOARLE LE-AM CURATAT SI SE PAREA CA MERG BINE. NU LA BOSCH CA NU EXISTA ASA CEVA PRIN TULCEA.MA IINCERC LUNI CEVA SI DUPA AIA O VAND DACA NU MERGE. GLUMESC.N-AS VINDE-O PTR NIMIC.
Edited by MISU
