F10 525d
InSidE
Multumesc pentru aprecieri.
Sper sa ajunga bordul saptamana asta.
Masina o sa primeasca folii spate+luneta Llumar, mi se pare mie sau a scazut pretul ? 250 ron :)
Este si pe fata din acelea transparente care reduc UV , se merita? 100 ron
Pretul este la centrul de parbrize autorizat Pilkington... dar tot mi se pare ieftin
Edited by InSidE
sa te uiti bune daca este llumar. folia llumar are folia transparenta pe care e lipita un text cu emblema llumar. il poti vedea cand o intinde sa o taie. si bineinteles nuanta foliei care este unica (trebuie sa cunosti nunta foliei)
succes
eu am asa pe fata. nu este legala. consider ca cea legala e ca si cum nu ar fi. ce.i drept, am probleme mereu cand sunt oprit. post-71747-0-74424600-1446631326_thumb.jpg
Merita si pe fata pt filtrul Uv . Si e buna si in caz de impact tine geamul .
In addition, the 2014 BMW 5 Series offers customers a new rear-seat entertainment system with tablet-style displays, a Harman Kardon Surround Sound system and a new version of the ambient light option with a facility which allows the interior lighting to be alternated in tone between orange and white.
Deci se pare ca HK a fost introdus din 2014
mai multe info:
Classic F10, the 677 option was Hifi Professional which was an unbranded 16 speaker system with basic Dirac processing. (The high-end B&O option has higher-end Dirac processing).
LCI F10, the 688 option is branded as Harman Kardon.
The US site makes no mention about Dirac processing and BMW NA is unable to answer the question of whether or not Diract processing is included. The international brochure says that the Harman Kardon sound setup has Dirac processing. With the July/August 704 M-Sport Suspension story, I'm going to assume that Dirac processing is limited to the EU models. Harman has good technology also, AuraVox.
There are 7x 26mm tweeters. 3 in front, 2 in the rear door, 2 in the rear shelf. These are Harman's Metal Matrix.
There are 7x 100mm woofers to go with the tweeters. I haven't taken delivery of my car yet, but I believe these are Alumaprene. Harman doesn't say what this is other than to say that it's better than woven aramide (kevlar).
There are 2x 217mm subwoofers under the front seats. These probably go down to 60Hz only.
The amp is a Class D amp which is rated at 600W but I don't know what the breakdown is. Since it's class D and they claim a lower wattage for the lower-end BMW's, it's probably a legitimate rating.
Edited by InSidE
Un teaser si cu 6wb, din pacate nu pot sa il codez ca nu am sters km ca nu am programator universal :( sa vedem de unde fac rost ca din china dureaza 1 luna pana ajunge..
este functional doar kilometraju, turatiile nu merg si am o gramada de erori din cauza optiunilor masinii dinainte..
http://s10.postimg.org/7lwd641yd/20151111_133306.jpg
Am observat o imbunatatire la HUD, imi apare pe HUD si melodiile, si contactele din telefon :)
Edited by InSidE
merge si pe 6WA, trebuie doar codate, ia la mana toti parametrii cu HUD_xxxxxxxxxxxx o sa gasesti HUD_BLINKER, HUD_ENTERTAINMENT, HUD_TLC (pentru LDW), HUD_TELEFONBUCH. Le-am citat din memorie, scuze daca sunt mici inadvertente.
@Inside: vino sambata si se rezolva, nu te enerva ca asta chiar e un retrofit simplu doar ca trebuie sa ai programatorul corect si nu face sens sa dai o groaza de bani pe el doar ca sa faci bordul tau. Daca il iei tre sa iti deschizi o toneta in fata la targ pentru samsari sa recuperezi investitia :D
