RDKS sensors
CNT
Imi voi raspunde singur, in ideea ca poate va interesa si pe altcineva pe viitor :
Incepand cu modelele F10 LCI, masinile au acesti direct RDK sensors care sunt explicati mai jos (text de pe Atu.de)
RDKS = Reifendruckkontrollsystem oder TPMS = Tyre Pressure Monitoring System
advantages
More safety for all road users through optimum tire pressure (braking distances, blowouts, cornering stability, ...)
No higher fuel consumption due to wrong tire pressure
Reduce tire wear due to perfect tire pressure
Minimization of CO² emission of each vehicle, reducing the greenhouse effect
Loss of tire pressure is immediately displayed and a deficiency can be remedied in good time
Air pressure must not be so frequently checked
Disadvantages
with a new set of wheels the sensors need to be re-learned on some vehicles in specialized stores
slightly higher cost of the sensors, but pay for themselves through the described benefits
Valve needs to be serviced with new tires
Legal requirements for the equipment of vehicles with a Tyre Pressure Monitoring Systems
Since 1 November 2012 all the EU newly homologated cars, SUVs and RVs must be equipped with TPMS. From 1 November 2014, all registrations of passenger cars, SUVs and RVs must have a TPMS in the EU. IMPORTANT: Retrofitting older vehicle registration is not necessary! In the general inspection of vehicles with a standard Tyre Pressure Monitoring Systems, a non-functioning TPMS as low deficiency §29 StVZO listed in the test report. This deficiency must be remedied immediately.
What's installed in my car and as I find it out?
a direct system displays on the screen exactly the air pressure (see vehicle manual)
an indirect system is a warning lamp in the car (see owner's manual)
a vehicle without TPMS has no ads in the vehicle cockpit
What is the difference between direct (active) and indirect (passive) TPMS?
direct (active) RDKS
the air pressure is displayed accurately in bar on the display, measurement tire pressure sensors
it must sensors at each wheel to be present
manual control of the air pressure is omitted
DANGER:
In a direct TPMS new sensors must be trained on the car, that is, during the assembly of a new wheelset following Anlernprozesse may occur, the / depend on the vehicle brand model:
selbstanlernende sensors
Teach about the vehicle menu
Teaching the sensors via the on-board diagnostics system
