Intalnire BMW Club 2025 ×
DSC III ca optiune ce inseamna
salut ,eu am pe masina ca optiune DSC iii,sunt curios daca aici mai intra alte optiuni si care sunt acestea,si ce diferenta este intre dsc 2 si dsc 3,merci
Dynamic Stability Control (DSC).
Dynamic Stability Control (DSC) not only optimises driving stability when starting or accelerating, it also improves traction. In addition, the system recognises unstable driving conditions such as under - or oversteering and helps to maintain a safe course for the vehicle.
Advanced sensory technology monitors the wheel rotation speed, lateral acceleration and the yaw rate (rotation around the vertical axis). This data is processed to obtain information about the automobile as it is currently moving, and is compared with data about how it should be currently moving, as supplied by the accelerator and the angle of the steering wheel.
If these two lists of data do not match and the automobiles stability is threatened, DSC is activated and influences the brake system or the engine management. This action helps prevent dangerous situations such as skidding.
