probleme pornire bmw e46
SALUT,AM UN BMW E46 150 CP DIN 2001 SI AM PROBLEME CU PORNIREA INDIFERENT CUM ESTE VREMEA AFARA,DAU LA AUTOMAT INVARTE DAR NU PORNESTE,AM TRAS-O SI NIMIC NICI MACAR UN SEMN SA PORNEASCA,DAR MAI ARE MOMENTE CAND SI PORNESTE,PUN CONTACTUL SI SE AUDE POMPA DE MOTORINA CUM BAGA,CAND NU PORNESTE PUN CONTACTUL SI NU SE AUDE NIMIC,AM VERIFICAT POMPA DIN REZERVOR SI MERGE ,I-AM SCHIMBAT RELEUL DE LA POMPA SI NIMIC ACELEASI SIMPTOME,AM PUS UN TESTER PE EA SI I-A DAT CA IN RAMPA ARE DOAR 50 BARI,CUM I-A MARIT PRESIUNEA IN RAMPA DIN TESTER LA 320 BARI I-A DAT CHEIE SI A PORNIT. NU CRED CA AR FI POMPA DE INALTE DE VINA,CA DACA AR FI FOST NU MAI PORNEA DELOC, MAI ARE VREUN RELEU PE UNDEVA SAU VREUN SENZOR,SA FIE SENZORII DIN CAPETELE LA RAMPA SAU VREO ELECTROVALVA,SA FIE DE LA CONTAC.
A MAI PATIT CINEVA ASA
VA ROG SA IMI SPUNETI SI MIE,NU STIU CE SA II MAI FAC,DE DOUA SAPTAMANI STA PE DREAPTA
ORICE SFAT E BINE VENIT
MULTUMESC
