cumpar radio cd professional pt bmw e87
BMW RADIO PROFESSIONAL for BMW E90/E91/E93/E80/E81/E82/E88/Z4 .....
with integrated BLUETOOTH, USB/AUX and DAB Radio. With MOST!
- remanufactured radio, condition as brand new. 100% functional, uncoded
Manufacture date 06 / 2011
- USB / AUX connection - included! (extension cable and USB/AUX connection box!)
Two-line display, Supports MP3/WMA, AUX-IN, Bluetooth
- rare version with DAB digital radio tuner! (requires connection of DAB antennas)
 CD Changer, Displays Bordcomputer Data and PDC, can control Independent heating etc.
- MOST Optical connection (can work with TOP HIFI L7)
Great feature of this radio is integrated bluetooth, and then you do not need any other additional module in your car like ULF or TCU. Only this radio and you can use bluetooth. It is necessary to install microphone with extension cable and connect it to the radio connector and afterwards radio must be coded in your vehicle! It may not work properly without coding!
Microphone and its connection is not included, must be purchased separately.
Http://www.befr.ebay.be/itm/BMW-Radio-Professional-Bluetooth-FSE-USB-DAB-AUX-E90-E91-E93-E80-E81-E82-E88-Z4-/141354951953
de aici asa reiese, ca mai este nevoie doar de microfon si de codare si ar trebui sa mearga.
radiocd-urile de pe e90 se potrivesc pe e87?
Edited by dan.l
