cic bmw
Navigatia este data jos de pe masina personala bmw f30 2012,piesele nu au urme de uzura,are ultimele harti 2016-1 cu cod liftime pentru actualizari de harta,dvd,internet,bmw live,apps.vremea,news,wiki,bluetooth,etc..
Am urmatoarele piese. Unitate,monitor mare 8,8inch,idrive ,combox media,cablul de la monitor la unitate.
Este in perfecta stare de functionare,fac si schimb cu faruri de bmw f30 modelul cu adaptiv.
pret 500euro negociabil
Multumesc
Edited by player31
sal,am gasit postarea asta pe un forum poate e valabila si pentru cic!!!
Yes, the emulator is available.
To install NBT in any E Series you need the following parts:
- NBT-HU from F30;
- NBT CID from F30 or F25;
- Touch Controller;
- Touch ECU;
- NBT Video Cable;
- USB/Aux Port for armrest;
- USB cable
- Faceplate for CIC according to your vehicle (frontpanel buttons); (if car has CIC the actual one can be reused)
- Monitor trim according to your vehicle; (if car has professional navigation CIC or CCC the actual one can be reused)
If car has CCC the following parts are also required:
- Dash trim for CIC headunit according to your vehicle;
- Console trim for CIC controller according to your vehicle;
Combox is not required anymore in NBT setup as NBT has built-in combox. NBT has 2 USB ports which will allow usb/ipod playback including VIDEO from USB, has built-in bluetooth for phone and music streaming. If car has bluetooth of any kinf (TCU/MULF/Combox) this must be removed. Microphone and BT aerial must be connected directly to NBT
Edited by player31
