ET la jante pentru e34
len69
cauta si tu pe net ca e simplu, E34 nu prea mai sunt pe toate drumurile ca sa stim "pe de rost" rolleyes.gif
uite ceva gasit in 2 minute
Wheel specifications:
Hub center diametre: 72.5 mm
Number of bolts: 5
Pattern: 120 mm (See picture)
Offset (ET): 20mm
The offset is the distance from the hub mounting surface to the centerline of the wheel. Wrong offset = bad handling.
http://www.bmwe34.net/E34main/Upgrade/Data/5bolt.gif
An ET22 wheel is further in toward the centerline of the car than an ET20 by 2mm. ET13 wheels are 7mm further out than the OE E34 wheels.
Edited by armin
