Alegere componente (Amplificator, Subwoofer si capacitor) audio
Bogdann87
Salutare.
Am de ales un amplificator, subwoofer sau difuzor + carcasa, capacitor, cabluri si convertor RCA.
Am de ales intre acestea:
1. Bass Face POWER12.2 2600W 12 inch Active Twin Subwoofer
2. Bass Face SPL12.3 5000 W 12-Inch (2500W RMS)
3. Bass Face SQ4.1 2000W 4 Channel Amplifier With Digital Signal Processing
4. Bass Face DB1.2 2500W Class-D Monoblock Subwoofer Amplifier
5. Bass Face SPL12.2 2500W 12 inch Dual Voice Coil (1250W RMS)
6. Speaker to RCA Converter
7. Bass Face CAP2.1 2 12V Farad
Merita sa iau acel Twin Subwoofer si nu amplificator separat cu unul din acele difuzoare? Eu vreau un bass sanatos si clar pe masina.
Pana la urma am ales aceste componente:
1. Lanzar VCT2610 6000W 2 Channel High Power Mosfet Amplifier
RMS Power @4 Ohms 300 watts x2
THD @4 Ohms 450 watts x2
RMS Power @2 Ohms 600 watts x2
THD @2 Ohms 900 watts x2
Maximum Power Output @2 Ohm 6,000 watts x1
Bridged Power @4ohm 8,000 watts x1
Low Level Impendance Input: 10K Ohms
Low Level Sensitivity Input: 200mV-6V Adjustable
S/N Ratio: 95dB
Channel Separation: 65dB
Chrossover Filters-
Low Pass:40 Hz-150 Hz
High Pass:40 Hz-250 Hz
Bass Boost: 0~+18dB
Sub Sonic Filter:10-100 Hz
Stereo Mode: 2-4 Ohms
Bridged Mode: 4-8 Ohms
Fuse Size: 60A x2
Power Supply Voltage: 14.4V DC Neg. Ground (10.5-16V)
2. JBL GT5-2402BR Dual 12 Inch Subwoofer
Type Enclosed Bass-Reflex Subwoofer
Low-Frequency Transducer Two 12" (300mm) Polypropylene cones
Voice Coil 2" (51mm) diameter
Power Handling, RMS 550 W
Power Handling, Peak 1600 W
Frequency Response 40Hz–200Hz
Nominal Impedance 2 ohms
Sensitivity (2.83V @1m) 95 dB
Enclosure Type Bass-reflex, with Slipstream port
Imi puteti spune daca am facut alegerea corecta si daca amplificatorul este ok, sau prea puternic pentru tubul de bass care are 550w RMS? Nu as vrea sa distrug/ard subwoofer-ul...
Edited by Bogdann87
