Schimbare parbriz - "SOUND INSULATION F APRON"
kpa
Trebuie sa astept pana luni iar intre timp ar fi trebuit sa dau deja comanda.
Am vorbit cu cineva la telefon dar nu parea ca stie ce si cum e cu banda aia.
Mi-a raspuns ceva de genul "fratele meu, nu cred ca ai nevoie de ea" :) (12 ani experienta)
Edited by kpa
intr-un final cred ca am gasit si utilizarea acelei benzi.
este o izolatie fonica pentru portiere dar se para ca fara ea exista si riscul de a avea probleme cu scurgerea apei in interiorul masinii.
https://sayyarti.wordpress.com/2014/04/17/bmw-335i-e90-2007-water-leak-in-passenger-side-after-windshield-replacment/
"BMW 335i E90 2007 water leak in passenger side after windshield replacment
I have replaced the front oem windshield in the local authorized BMW dealer they have replaced the following parts:
1- 51317203857 Windshield for vehicles with climate comfort windscreen and rain & light sensor.
2- 51317061967 Windshield Moulding – Upper.
3- 51137133292 Windshield Moulding – Lower.
4- 51717180743 Rain Tray / Water Deflector.
5- 64116928326 Condensation Sensor ( it is behined the rear view mirror cover you cant use the old one, it will break if you take it out)
and they used OEM polyurethane BMW / MINI adhesive: 83190444144
The fix !:
it appears that leak is not from the windshield it is from the seal of the door vapor barrier AKA Sound Insulating foam.
this barrier is sticked to the door using Butylband tape (Butylene tape) from BMW:
Part Number 83190153321
No more water leaks during rain of car wash and nothing was wrong in the sealing of the windshield."
am atasat parte din text pentru situatia in care pagina va disparea.
Silviu.
  • 4 years later...
Silviu,
Te-ai mai lamurit cu problema asta? In textul preluat de tine pare sa fie alta problema totusi si alt cod de piesa. Eu pt e46 am nevoie, ramane aceeasi intrebare.
Cei de la parbrize n-au nici o ideea ce ar putea fi piesa aia.
Schema pe realoem: https://www.realoem.com/bmw/enUS/showparts?id=AP71-EUR-10-2004-E46-BMW-320d&diagId=51_3823
Acuma vreau sa schimb si eu parbrizul si nu stiu exact ce mai trebuie pe langa parbriz:
- chederul, pozitia 1 in schema de pe realoem, cred ca trebuie si l-as lua pe original ca celelalte nu protejeaza tabla in partea de sus, din ce am vazut eu;
- mai sunt niste tampoane pt ornament, pozitia 2 in schema; nu stiu exact la ce folosesc, dar is ieftine asa ca le-as lua si vedem;
- kit de adeziv original n-as lua ca ii cam scump la 235 lei, plus ii inclus in pretul de montaj de 150 lei, unde vreau sa fac lucrarea; tot cu timp de uscare de 1 ora.
- mai este banda izolatoare parbriz, pozitia 5, asta ii cea despre care ai intrebat si tu; ii cam scumpa la 200 lei, mai ales ca nu stiu exact ce face si daca trebuie schimbata sau nu odata cu parbrizul.
Sebi
