Navi F10
ghitulescu
Vrei sa dea cineva search pe google pentru tine? Ti-e lene sa cauti sau nu stii ce sa cauti? Le. Uite aici din primul link gasit pe net. Main advantages of CIC Retrofit over CCC Navigation System ââŹÂ˘ Internal hard drive (80GB): maps and music can be stored on hard drive ââŹÂ˘ Faster processor (faster response speed) ââŹÂ˘ Better graphics ââŹÂ˘ No more overheating issue ââŹÂ˘ Huge step forward from the older CCC ââŹÂ˘ More ergonomic design ââŹÂ˘ CIC permits other multimedia retrofits to be added: Combox, BMW Apps, BMW plug-in Main advantages of NBT Retrofit over CIC Retrofit ââŹÂ˘ 200GB hard drive instead of 80GB drive (available in CIC) ââŹÂ˘ Combox built-in ââŹÂ˘ Faster processor (faster response speed) ââŹÂ˘ Better graphics / higher contract ââŹÂ˘ Sports Display (real-time power and torque meters) ââŹÂ˘ M-lap timer ââŹÂ˘ Ability to stream video from USB in the armrest (CIC does not allow this) ââŹÂ˘ BMW Apps ââŹÂ˘ 3D maps CIC Retrofit vs. NBT Retrofit If you are still not sure which retrofit is right for you, please consider the following: ââŹÂ˘ NBT is the ââŹĹTOTAL UPGRADEââŹÂ system, which comes with all ââŹĹbells and whistlesââŹÂ, whereas CIC retrofit allows ââŹĹSTEP-BY-STEP UPGRADEââŹÂ, which makes CIC retrofit more affordable. i.e. you can first do CIC retrofit, than Combox Retrofit, than BMW Apps. ââŹÂ˘ NBT retrofit is more modern, offers more features, better graphics, faster processor, bigger hard drive, etc. ââŹÂ˘ CIC retrofit is generally more affordable than NBT retrofit, BUT please keep in mind that: price of both CIC retrofit and NBT retrofit depends on vehicleââŹâ˘s configuration and your needs ââŹâ price of NBT retrofit may be a more costly option for one customer, but a more affordable option for another customer! Edited by mcliviu
O sa pun repost, ca am scris de pe telefon si a iesit o varza.
07/2012 – CIC was superseded by an NBT Navigation System, and NBT currently is the latest Navigation System which is installed in BMW F-series from factory. We released a special adapter, called eNBT Retrofit Adapter, which permits installation of NBT into E-series, so NBT retrofit is an option for owners of E-series as well.
• Internal hard drive (80GB): maps and music can be stored on hard drive
• Faster processor (faster response speed)
• Better graphics
• No more overheating issue
• Huge step forward from the older CCC
• More ergonomic design
• CIC permits other multimedia retrofits to be added: Combox, BMW Apps, BMW plug-in
• 200GB hard drive instead of 80GB drive (available in CIC)
• Combox built-in
• Better graphics / higher contract
• Sports Display (real-time power and torque meters)
• M-lap timer
• Ability to stream video from USB in the armrest (CIC does not allow this)
• BMW Apps
• 3D maps
• NBT is the “TOTAL UPGRADE” system, which comes with all “bells and whistles”, whereas CIC retrofit allows “STEP-BY-STEP UPGRADE”, which makes CIC retrofit more affordable. i.e. you can first do CIC retrofit, than Combox Retrofit, than BMW Apps.
• NBT retrofit is more modern, offers more features, better graphics, faster processor, bigger hard drive, etc.
• CIC retrofit is generally more affordable than NBT retrofit, BUT please keep in mind that:
