ISTA v4.04.31
ISTA v4.04.31 - DOWNLOAD
SQLiteDBs (Baza de Date) - DOWNLOAD
Installation:
1. Install .Net Framework 4.5.2 version and up, from Microsoft
2. Install Java.
3. Download and install the Microsoft Visual C++ 2010/2013 Redistributable Package x86/x64 from Microsoft for your language in Windows.
*** for computer x86:
- vs90_piaredist
- vcredist_x86_2005
- vcredist_x86_2008
- vcredist_x86_2010
- vcredist_x86_2012
- vcredist_x86_2013
- vcredist_x86_2015
*** for computer x64:
- vs90_piaredist
- vcredist_x64_2005
- vcredist_x64_2008
- vcredist_x64_2010
- vcredist_x64_2012
- vcredist_x64_2013
- vcredist_x64_2015
If the system is x64, vcredist must install x86 and x64, otherwise not start Rheingold.
4. Install Ediabas 7.3
5. Unblock archive if necessary. It is important to not skip this step! Unblock file, uncheck Attributes - Read-only. Then unzip.
6. Unzip to any directory, for example: C:\Rheingold, D:\Rheingold, E:\Rheingold..., C:\Program Files\, C:\Program Files (x86) - this folder for 64bit computers. You can run from USB stick too.
7. Unzip and copy SQLiteDBs in Rheingold\SQLiteDBs\
8. Add additional languages if necessary in SQLiteDBs
9. Start RCleaner. Run as administrator.
10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
11. Start Rheingold (...\Rheingold\TesterGUI\bin\Release\ISTAGUI.exe) Run as administrator.
12. Enter the license key from the license.txt, if ask.
13. Enter 1 in the field of ISIS, ignore the error.
  • Like 5
Am facut toti pasii de mai sus si ISTA ruleaza. Folosind o interfata K+DCAN ( e60 LCI ) incerc sa intru in ISTA, dau pe operations - > read out vehicle data -> complete identification si imi da urmatoarea eroare "vehicle could not be identified". Pe youtube am vazut ca trebuie sa apara o fereastra "connection manager" in care aleg "ICOM13" sau ceva de genu. La setarile ISTA am ales ediabas default si tot la fel face.
1. Ce trebuie sa fac ca sa imi afiseze interfata si sa imi recunoasca masina?
2. Trebuie sa pornesc masina de fiecare data cand rulez ISTA? Sau pot proceda si altfel? Am butonul start/stop engine.
Edited by Brokencyde
Schimba de pe edibas pe ICOM/ENET local connection , este suficent doar sa ai contactu pus, conectezi cablu la masina, laptop si dupa rulezi ISTA -> operations - > read out vehicle data -> connection manager (alegi ICOM)-> complete identification ...
Am rezolvat. Am conectat cablul K+DCAN la laptop, am intrat in device manager si am schimbat portul cu COM9 si latency timer cu 1 pentru interfata.Pe urma am accesat folderul Ediabas, in ediabas.ini am facut urmatoarele setari “Interface = STD:OBD" si “Port = 6801". In obd.ini am schimbat cu “Port=Com9". Iar in ISTA, la settings->VCI Config->am selectat Ediabas standard settings. Pe urma am rulat operations - > read out vehicle data , toate modulele imi apar cu verde, am dat pe fault memory, 0 erori. In bord imi apare eroarea cu filtrul de particule, am cautat pe net sa accesez DPF-ul dar vad ca imi lipseste tabul "activities". Cum pot verifica DPF-ul, bujiile, releul de bujii, injectoarele etc.. in ISTA? Edited by Brokencyde
Salut. Din ce am vazut pe youtube, toate erorile legate de bujii, releu, DPF ar trebui sa apara in fault memory, nu?De cateva zile imi apare in Idrive eroarea cu filtrul de particule, dar cateodata nu mi-o mai arata ( masina are 148 000 km reali ) . Am facut anul trecut o diagnoza la BMW si mi-au spus ca este o eroare la o bujie. Mie nu imi arata nicio eroare in ISTA-D. Sa fie ceva in neregula cu interfata, softul sau masina?
Sincer iti spun ca nu stiu..Eu am stat in sala de asteptare cat timp au facut diagnoza. Nu stiu cu ce soft fac astia de la reprezentanta bmw diagnoza. Sa incerc si cu INPA? Daca in ISTA imi apare no fault memory dupa diagnoza, de ce imi apare in iDrive eroarea DPF-ului? Edited by Brokencyde
Am cautat pe google "Rheingold configuration manual.pdf" si am folosit pasii pt k+DCAN. Mai este un articol pt "Using BMW Rheingold ISTA with ICOM" in acelasi pdf, dar am cablu K+DCAN. Sa folosesc ista pe ICOM/ENET local connection cu cablu k+DCAN? Edited by Brokencyde
Modifica prima data doar conficuratie din ISTA , comuta de pe edibas pe ICOM/ENET local connection
Am comutat pe ICOM/ENET local connection si nu imi apare interfata in fereastra connection manager, nu pot sa dau pe set up connection. Am rulat si acel fisier network tool.exe. Dupa restart mi-a aparut o conexiune noua la retea cu ip-ul si mask-ul predefinit. Ista imi merge doar pe ediabas. Ar fi bine daca imi poate spune un coleg care ruleaza ista cu K+DCAN cu setarile pt ICOM/ENET local connection cum trebuie sa procedez.
Ma indoiesc ca ISTA nu imi merge bine fiindca imi vede masina, imi apar informatiile despre ea dupa finalizarea diagnozei. Erori nu am dar totusi imi apare cateodata in iDrive eroarea cu filtrul de particule. Daca merg mai sportiv, dispare eroarea.
Celor de la reprezentanta le-a iesit la diagnoza o eroare pt o bujie, senzor inaltime spate. De aceea ma gandeam ca s-a infundat filtrul de particule, fiindca din ce am citit pe forum nu se regenereaza daca nu sunt toate bujiile functionale si releul functional. Ca o fi adevarat nu stiu fiindca devizul trimis de ei ulterior are un cost foarte mare, 13 700lei si include releu, bujii, brate, bascule etc..
In orice caz, saptamana viitoare ma duc la service pentru o diagnoza si ma programez pt alta saptamana pentru curatarea galeriei de admisie.
Pana la urma, am fost la un service pentru diagnoza motorului si am 2 bujii arse si filtrul de particule infundat. Nefiind toate bujiile functionale, DPF-ul s-a infundat. Cand am scanat cu ISTA/D pe laptopul meu nu imi aparea nicio eroare. Interfata este versiunea 2014 cu Chip FTDI + Procesor Atmega. Incerc saptamana viitoare sa reinstalez windowsul si cea mai noua versiune de ISTA/D care-i pe forum. Probabil interfata nu este buna... Edited by Brokencyde
Totusi am vazut in screenshoturile anumitor versiuni de ISTA/D ca apar ceva articole ( ISTA version 4.04 .... - cred ca arata ce s-a mai optimizat la aplicatie ) in fereastra NEWS cand porneste ISTA/D. La mine nu imi apare niciun articol. Atunci este posibil sa fie de la ISTA/D.
Eu zic sa faci un print si sa ne areti ce ai tu pe acolo ... Daca nu ai ista 4.05.31 , sa o instalezi pe asta ca este ultima. Dar pana atunci baga in print, si sa nu uiti sa dai pe cheita de sus in bara si dupa da la version , fa in print si acolo.
