320D Sedan - Automatic Transmision
JamesGhost
Salutare tuturor!
Vreau sa va prezint si eu masina mea, si in acelasi timp sa impart impresii si pareri cu alti posesori de E46 Diesel atat cu transmisie automata cat si manuala.
Masina am achizitionato acum o luna, pentru 1100Lire.
Masina are cam multi KM (170k Mile - 273k km) dar inca se tine bine, fapt care m-a si impins sa o iau.
Mai jos sunt optiunile si detalii:
Vehicle information
VIN WBAAS72010FY83394
Type code AS72
Type 320D (EUR)
E series E46 (4FL)
Series 3
Type LIM
Steering RL
Doors 4
Engine M47DO1
Displacement 2.00
Power 110
Drive HECK
Transmission AUT
Colour SILBERGRAU METALLIC (A08)
Upholstery STOFF JACQUARD/ANTHRAZIT (H9AT)
Prod.date 2004-06-11
Vehicle options
S1CA Selection of COP relevant vehicles
S205 Automatic transmission
S226 Sports suspension settings
S249 Multifunction f steering wheel
S2CD BMW light alloy wheel, spider spoke 136
S302 Alarm system
S320 Deleted, model lettering
S321 Exterior parts in vehicle color
S428 Warning triangle and first aid kit
S441 Smoker package
S465 Through-loading system
S473 Armrest front
S493 Storage compartment package
S495 3-point belt and headrest, center rear
S508 Park Distance Control (PDC)
Vehicle options
S520 Fog lights
S650 CD player
S661 Radio BMW Business (C43)
S692 Preparation, BMW 6-CD changer I-bus
S710 M leather steering wheel
S775 Headlining anthracite
S785 White direction indicator lights
S7NA BMW Service Inclusive
L812 National version England / Ireland
S850 Dummy-SALAPA
S863 Retailer Directory Europe
S877 Delete cross-pattern operation
S880 On-board vehicle literature English
S8SM Car ident. number visible from outside
S8SP Control unit COP
Vehicle options
S210 Dynamic stability control
S530 Air conditioning
S832 Battery in luggage compartment
S853 Language version English
Astept pareri sincere si ceva sfaturi, ce si cum :)
Multumesc
Florin
EI hai, ca nici nu am postat bine prezentarea ca revin cu o mica problema la masina :(
Am fost sa dau o tura de cartier pana la un magazin romanesc, si cand m-am intors martorul de DSC si cel de Frana de mana s-au aprins.
Am tras pe stanga, insa am observat ca franele nu mai sunt la fel de eficiente :(
Am facut o scanare rapida, si am codul 149 Can Wheel Speed Signal, si ceva de Brake Pressure Sensor.
Careva idee ce senzor este in cauza? Cumva aia doi de pe pompa de frana?
Thanks
brake pressure sensor e in pompa de ABS, o valva mai exact pe blocul de valve de pe pompa de frana unde este si ABS-ul. Se poate desface doar partea electronica si trimisa la reconditionat, cauta pe google, sunt firme in UK care pot face asta. Poti vedea cred cu INPA valorile senzorului cand apesi pedala de frana.
Merci! O sa fac testul maine. Momentan sunt la job :)
Este totusi ciudat, ca asa cum am zis, abs nu am aprins si merge, am decat martorul de ESP si acela cu semnul exclamarii.
Faza e ca si franele sunt mult mai prostute, la modul ca trebuie sa apas pedala mai tare ca sa fie eficienta franarea.
Totodata, martorul se aprinde imediat de la pornirea motorului, fara a fi nevoie sa mut masina din loc.
Vad maine ce zice inpa...
Am aruncat o privire acum pe forumuri si se pare ca BMW a folosit o revizie noua la un moment dat pentru FL :)
Senzorii aia doi care sunt pe pompa, sunt senzori de fapt senzori de presiune pentru frane, unul pentru fata, unul pentru spate.
Totodata, si modulul DSC is ia informatii din acei senzori.
Vezi poza atasata cu detalii..
Salutare,
Revin cu noi detalii, si implicit solutionarea "Problemelor"
Am fost azi la service pentru inlocuirea celor doi senzori de pe pompa (DSC Presure Sensor), crezand ca aceia sunt problema.
Insa, nici dupa schimbare, problema nu a disparut.
Asa ca m-am gandit sa fac o aerisire a sistemului de franare vazand ca pedala este foarte moale...
Zis si facut, ne-am apucat, doar ca in timpul "procedurii" am observat o scurgere de lichid undeva langa rezervor :)
Asa ca, am stiut sigur ca aceea poate fi o problema majora :).
Am Schimbat conducta, care curgea, si am rezolvat TOATE problemele acum....
Nu mai am martori aprinsi, am frane bune, si nici masina nu mai da sa se repeada pe masina din fata cand mut din N in D frantics.gif
Sper sa ma tina mult si bine :))
