ISTA v4.05.23
ISTA 4.05.23 - DOWNLOAD
SQLiteDBs (baza de date) - DOWNLOAD
Tools - DOWNLOAD
Folositi 7zip pentru a dezarhiva SQLiteDBs (baza de date) - DOWNLOAD
Installation:
1. Install .Net Framework 4.5.2 version and up, from Microsoft
2. Install Java.
3. Download and install the Microsoft Visual C++ 2010/2013 Redistributable Package x86/x64 from Microsoft for your language in Windows.
*** for computer x86:
- vs90_piaredist
- vcredist_x86_2005
- vcredist_x86_2008
- vcredist_x86_2010
- vcredist_x86_2012
- vcredist_x86_2013
- vcredist_x86_2015
*** for computer x64:
- vs90_piaredist
- vcredist_x64_2005
- vcredist_x64_2008
- vcredist_x64_2010
- vcredist_x64_2012
- vcredist_x64_2013
- vcredist_x64_2015
If the system is x64, vcredist must install x86 and x64, otherwise not start Rheingold.
4. Install Ediabas 7.3
5. Unblock archive if necessary. It is important to not skip this step! Unblock file, uncheck Attributes - Read-only. Then unzip.
6. Unzip to any directory, for example: C:\Rheingold, D:\Rheingold, E:\Rheingold..., C:\Program Files\, C:\Program Files (x86) - this folder for 64bit computers. You can run from USB stick too.
7. Unzip and copy SQLiteDBs in Rheingold\SQLiteDBs\
8. Add additional languages if necessary in SQLiteDBs
9. Start RCleaner. Run as administrator.
10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
11. Start Rheingold (...\Rheingold\TesterGUI\bin\Release\ISTAGUI.exe) Run as administrator.
12. Enter the license key from the license.txt, if ask.
13. Enter 1 in the field of ISIS, ignore the error.
Edited by X X L
  • Like 6
ISTA 4.05.31 - DOWNLOAD
Pentru cine are deja instalat versiune anterioara 4.05.23, doar dezarhivati ISTA si mutati fisierele din folderul SQLiteDBs (baza de date) din ISTA vechi in folderul SQLiteDBs din ISTA nou, si aplicati iarasi registry ISTA-D and SQLiteDBs Reg Fix.
Pentru cine instaleaza ISTA prima data , folositi ISTA din linku asta si urmati doar pasii de mai sus.
Rog un moderator sa inlocuiasca linkul din primul post cu linkul acesta , si numele din ISTA 4.05.23 in ISTA 4.05.31, daca se poate si din titlul topicului. Multam !
Edited by OPaul
Salut!
Aveti idee cum se downloadeaza de pe mega.nz?
Am facut cont pe site la mega.nz iar din cei 11 GB cat are SQliteDB ma lasa sa iau decat 5Gb, apoi zice ca am depasit limita de 5Gb si ca trebuie sa astept 8 ore....
Daca astept 8 ore cu PC pornit, o va lua iar de la capat? Sau continua downloadul de unde a ramas de la 5GB in sus?
Merci!
La versiunile noi, 4.xx, am eroare cu Net Framework si nu pot instala 4.6.2 deoarece nu am SP1 pe laptop.
Am bagat 3.54.12 (din anul 2016 de pe la inceput), aveti idee daca imi va merge la fel ca astea noi? Adica ma intereseaza sa pot citi erorile cu el, parametrii reali in special injectoare, la un E60, an 2006.
Am si eu o intrebare. Merge sa descarc ISTA-D din linkul tau, baza de date doar ENG (de 690 MB) si Tools, si sa instalez testerul pe mufa K+D-CAN?
Citisem ca trebuie descarcate toate, deci peste 120 GB, si dureaza o groaza la instalare.
Daca vrei doar sa il folosesti pentru diagnoza, ISTA ocupa 20 giga.
Asta am inteles, il folosesc doar pt. diagnoza.
Legat de intrebarea de mai sus, poti sa iti dai cu parerea?
Si inca ceva, dupa ce instalez programul conform pasilor de mai sus, intru in el, si apoi setez ca optiune la setting sa ia setarile din ediabas.ini nu?
Si mufa K+D-CAN o instalez ca la INPA? Adica bag usb-ul in laptop, astept sa isi instaleze driverele, apoi setez COM1 si latency din 16 in 1 si atat?
Stie cineva de ce nu se conecteaza INPA la masina (nici baterie nici ignition)
Am instalat 2 versiuni de INPA dar si ISTA D. Toate pe Windows-uri 10 curate
Cu nicio varianta nu s-a conectat. Nu mi-a dat nicio eroare la instalari,INPA porneste,si ISTAD dar nu vede conexiune.
Am facut exact pasii din instructiuni.
Am mutat portul pe COM1,Latency 1,LED-ul mufei (adaptorului) e aprins. Am incercat pe mini 2002 si e90 lci
Asta e cablul : USB K+D-CAN DCAN USB Interface
Am pus ald HDD pe laptop,windows10 nou, toate setarile din postul asta exceptand SQLiteDBs Reg Fix bit for your system from the Tools folder, nu l-am gasit in tools.
Am setat port COM9, latency 1 si tot nimic.
Tind sa cred ca desi se instaleaza cablul,LED-ul e aprins, e defect
Da , eu am gasit unu foarte misto la 1.5$, il am deja de aproape 2 ani si nu am avut probleme pana acuma.
Imi place mult ca are si mufa la cablu si in caz ca iti face figure poti sa il schimbi scurt.
Ia intra in obd.ini din partitia C din folderul Ediabas, si vezi pe acolo ce port e setat, ma refer la COM.
Edited by alynxs
