ISTA-D 4.06.22 Standalone / ISTA-P 3.62.1.003
Teoretic trebuie sa mearga pe orice Windows. Anyway, bine ca merge :D
Am alta problema acum, am reusit sa ma conectez la masina, o recunoaste, pot sa verific daca am erori, pot vedea si tree-ul cu control units, dar cand intru la [Vehicle management ->Service functions] nu imi apare nimic. Sa fie o problema hardware sau sa incerc alta versiune de ISTA?
In Torrent o sa aveti tot pachetul ISTA-D (diagnoza/programare), ISTA-P (programare) si bazele de date aferente. DOWNLOAD
Pentru a instala doar ISTA-D trebuie sa bifati din Torrent: ISTA-D , SQLiteDBs si Tools (Pentru cine are ICOM si vrea sa faca si programare cu ISTA-D poate sa bifeze si SDP care se dezarhiveaza si se copiaza in folderul PSdZ din ISTA-D)
Pentru a instala ISTA-P aveti ghidul in folderul Tools - FAQ-EN.pdf iar pentru ISTA-D trebuie doar sa urmati ghidul de mai jos.
Installation:
1. Install .Net Framework 4.5.2 version and up, from Microsoft or Tools folder.
2. Install Java.
3. Download and install the Microsoft Visual C++ 2010/2013 Redistributable Package x86/x64 from Microsoft for your language in Windows.
*** for computer x86:
- vs90_piaredist
- vcredist_x86_2005
- vcredist_x86_2008
- vcredist_x86_2010
- vcredist_x86_2012
- vcredist_x86_2013
- vcredist_x86_2015
*** for computer x64:
- vs90_piaredist
- vcredist_x64_2005
- vcredist_x64_2008
- vcredist_x64_2010
- vcredist_x64_2012
- vcredist_x64_2013
- vcredist_x64_2015
If the system is x64, vcredist must install x86 and x64, otherwise not start Rheingold.
4. Install Ediabas 7.3
5. Unblock archive if necessary. It is important to not skip this step! Unblock file, uncheck Attributes - Read-only. Then unzip.
6. Unzip to any directory, for example: C:\Rheingold, D:\Rheingold, E:\Rheingold..., C:\Program Files\, C:\Program Files (x86) - this folder for 64bit computers. You can run from USB stick too.
7. Unzip and copy SQLiteDBs in Rheingold\SQLiteDBs\
8. Add additional languages if necessary in SQLiteDBs
9. Start RCleaner. Run as administrator.
10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
11. Start Rheingold (...\Rheingold\TesterGUI\bin\Release\ISTAGUI.exe) Run as administrator.
12. Enter the license key from the license.txt, if ask.
13. Enter 1 in the field of ISIS, ignore the error.
Am urmat pasii, am instalat/reinstalat TOT (DOAR Ista-D ma intereseaza), am respectat fiecare pas in parte, respectiv am dezarhivat cu 7zip. Atat versiunea postata in primul post cat si versiunea postata anterior imi da urmatoarea eroare (poza atasata). Vorbim de Win7 32 bit. Ma poate ajuta un coleg sa imi pot instala (in sfarsit) programul? Va multumesc anticipat!
Mi-a venit azi al doilea cablu, cu buton pt k-dcan.
Surpriza,cand bag mufa in laptop,nu-l recunoaste,nu se intampla nimic. Pe primul cel putin il recunostea laptopul
Am pus alt win7 32biti,nu-l vede....Led-ul se aprinde cand il mufez la masina dar dupa 1 min se stinge
Oare sa fie ghinionul asa mare? ...II cer banii aluia inapoi
Cand deschid programul imi cere cod de activare,il folosesc de vreo 2 ani dar acum imi cere cod:
"Unfortunately your local copy is not activated yet. It's necessary to activate your local installation via an authenticated license. Please follow the steps in the next dialogs."
Cum pot rezolva?Versiunea pe care o am e veche 3.41
https://mega.nz/#F!6Z4iHbib!o5fxC0tuYqdCM32zvlD0yQ
SQLiteDBs 4.06.31 RU, EN, DE, OTHER.
Just unpack with 7-zip in SQLiteDBs folder base U need.
Nu merge cu MegaDownloader ĂŽmi tot dĂŁ eroare când ajung la fișierul de 10GB.
Ce pot sĂŁ fac, pentru cĂŁ prin MEGA ”oficial” nu pot.
Am reusit pana la urma sa-mi instalez pe un alt laptop (4gb ddr3 ram) programul. Am facut TOTUL ca in primul post dar am urmatoarea eroare : "The connection to one of the required databases could not be established. Please check DSS #00046632EN for further trouble shooting"
Intrebare : 10. Apply ISTA-D and SQLiteDBs Reg Fix bit for your system from the Tools folder.
La acest punct zice si de SQLiteDBs Reg Fix dar acest fisier NU se afla in TOOLS (de fapt nu se gaseste nicaieri). De copiat am copiat in folder Rheingold/SQLiteDBs urmatoarele fisiere (din arhiva, doar engleza) : streamdataprimitive_ENGB.sqlite (288 kb) si xmlvalueprimitive_ENGB.sqlite (7,97 GB)
Ma puteti ajuta va rog?
Am rezolvat cu ajutorul colegului @kenbobo (caruia ii multumesc mult). Trebuie dezarhivat si "others" si copiat tot in folder SQLiteDBs
Salut, primesc erori de genul: [Error in testmodule: ABL_DIT_XXXXXXXX] atunci cand vreau sa lansez o procedura din meniul "Service functions". Eu vreau in special sa fac o regenerare DPF, dar am intrat si in alte layere si tot eroarea asta o primesc, doar cu coduri diferite in loc de XXXXXX.
A mai patit cineva, o fi de la aplicatie, imi lipsesc mie ceva fisiere sau ceva de la masina nu ma lasa sa fac chestia aia?
