Dvd navigation block
E61 lci navi bussines are optiunea butonului Eject blocata , am sa va citez un paragraf gasit pe forum din afara
The optional extra ?anti-theft protection navigation DVD? enables a DVD lock of the navigation DVD for corporate customers. The corporate customer vehicles are delivered ex works with this optional extra. Vehicles can also be upgraded by means of the Progman and then adjusted with this service function.
New vehicles are delivered with the following default settings:
DVD lock always active: the eject button is disabled.
Up to model year 03/2006, vehicles were delivered with the following default settings:
DVD lock with PIN query active.
The default 4-digit PIN is XXXX.
The 4-digit PIN is queried when the eject button is operated. When the PIN is entered, the navigation DVD is ejected.
This service function can be used to read out or change the settings of the DVD lock.
Activating or deactivating the DVD lock
The DVD lock has the three possible states described below:
DVD lock inactive: the navigation DVD is ejected when the eject button is operated.
DVD lock with PIN query active: the set 4-digit PIN is queried when the eject button is operated. When the PIN is entered, the navigation DVD is ejected.
This service function can be used to change the 4-digit PIN.
Cine e priceput la codarii si a intampinat problema asta sa mi spuna parametrul care trebuie activat si cu ce soft. In Focsani am fost in 2 locuri unde fac tot felul de activari la bmw insa baietii nu au intalnit un caz similar si nu stiu unde sa caute .
Multumesc anticipat!
Ai nevoie de un NCS Expert si cablu K+DCAN ca sa citesti ce setari ai facute pe navi. Apoi trebuie gasita exact codarea pentru buton si activata.
Cablu gasesti la tot pasul, legat de NCS (si INPA, WinKFP, etc) gasesti VM-uri gata configurate pe diverse site-uri.
Ideea e ca cel mai simplu e sa iti citeasca cineva codarile de pe masina (sa le extraga) ca e dificil de "ghicit" care e codarea respectiva.
LE: ai aici un link , foloseste google translate. DVD_EJECT_LOCKED pare a fi setarea, trebuie sa aiba valoarea FREE conform linkului.
Edited by jeezy
MASK zice ca ar fi modulul, tu avand navi business.
De incercat! Daca baietii au mai codat masini si au putintica experienta, ar trebui sa se descurce. Google is your friend :)
PS: Daca nu prea au experienta, as zice sa iti ejecteze doar DVD-ul si sa il bagi pe celalaltul. Decat experimente, mai bine mers la sigur fara editat chestii.
Edited by jeezy
Pai nu e de editat nimic din ce am citi pe forumurile straine e doar o chestie de bifat insa fiind o chestie noua pt ei si marea majoritate a termenilor sunt in germana nu stim parametrul care trebuie schimbat. Am stat si eu personal peste 45 de minute si am luat o pe bajbaite insa nu am gasit . De asta intreb poate e cineva care stie unde sa ne uitam exact. Extragerea fizica fortata e exclusa, pina la urma ma duc la reprezentanta la Galati si tot il fac insa speram sa o rezolv in Focsani daca am informatiile necesare!
Daca citesti cu atentie linkul, o sa vezi ca zice acolo sa editezi FA-ul si sa scoti optiunea 6UE (daca exista). Asta inseamna ca trebe rescris FA-ul in CAS si LMA (sau FRM/NFRM in functie de ce ai pe masina). Apoi codat MASK-ul cu valoarea FREE pentru parametrul ala. Adica destul de multe de facut.
Alternativa ar fi din INPA, daca se poate, sa ejecteze DVD-ul si sa il bagi pe ala nou, e mai putin invaziva metoda.
Oricum, trebe investigat ce e pe masina, ca nu prea gasesti 2 la fel, eu abia am gasit ca trebe modificat numele unui fisier IPO in NCS ca sa reusesc sa citesc MASK-ul (eu am varianta fara navi).
Daca oamenii aia nu au mai facut codari si nu vrei experimente pe masina, keep it simple.
LE: la fel cum am gasit eu pe Google, pot si ei/tu. Mai ok ar fi sa iti iei un cablu K+DCAN si sa te familiarizezi cu programele astea.
LE2: Nu exista bifat optiune, exista citit codarile -> fisier cu extensia TRC -> il salvezi cu extensia MAN -> modifici ce parametru doresti cu notepad => rescrii TOT fisierul. Asta pentru NCS.
La Carly bifezi si codezi. Asta daca stie, ca nu poate coda tot nici Carly, deaia e mai bun NCS desi e mai dificil de lucrat cu el.
Eu nu pot coda nimic la MASK cu Carly, desi am adaptor cumparat de la ei si aplicatia platita din AppStore, nu stie citi MASK-ul meu.
Edited by jeezy
