Hill assist e90 320d
cristiano115
Salut!! De vre-o 2-3 luni detin un BMW 320D E90 163Hp MANUAL
Din cate am citit, absolut toate Bmw-urile E90 vin dotate din fabrica cu optinea (Hill assist) dar din pacate la mine nu functioneaza <_<
Daca stau in panta in viteza 1 cu piciorul pe ambreiaj si pe frana, in momentul in care las frana masina merge spate, ceea ce nu ar trebui sa se intample pt ca ar trebui sa intervina Hill assist-ul..
Daca are vre-o importanta:
Placutele sunt noi
Senzorii de frana sunt noi
Discurile sunt noi
Lichid frana nou si la nivel
Frana de mana este reglata
Se poate sa fie cumva dezactivat de fostul proprietar ? :umbrage:
HDC Hill Descent Control
The concept
HDC is a system for driving downhill in steep terrain. This system reduces vehicle speed on steep downhill gradients, thus allowing you to maintain control of your BMW under these conditions.
The vehicle moves at slightly more than walking speed without active intervention from the driver.
HDC is available for activation at vehicle speeds below approx. 20 mph/ 35 km/h. When driving down steep hills with a speed below approx. 20 mph/
35 km/h, the vehicle reduces speed automatically down to slightly more than walking speed, approx. 5 mph/ 8 km/h, and then maintains this speed.
You can use the accelerator or brakes to vary this automatically controlled speed within a range extending from approx. 3 mph/5 km/h to 15 mph/ 25 km/h.
You can specify a target speed within the same range by using the +/– buttons of the cruise control.
HDC is automatically deactivated once vehicle speed again exceeds approx. 35 mph/60 km/h.
Activating the system
Press the button, the indicator lamp lights up.
The indicator lamp flashes when the brakes are applied automatically.
Deactivating the system
Press the button again; the indicator lamp goes out.
HDC is deactivated automatically above a road speed of approx. 35 mph/ 60 km/h and when the ignition is switched off.
Using HDC
With manual transmission:
Use HDC in first gear and in Reverse since the engine's braking effect is diminished in the higher gears.
With automatic transmission: You can use HDC in every drive position.
In case of a malfunction
The indicator lamp in the button goes out in the HDC mode or does not come on when HDC is switched on: HDC is temporarily not available if brake temperature is too high.
If the indicator lamp also lights up: A fault as occurred in the HDC system. Have your BMW Sports Activity Vehicle center inspect this system as soon as
possible.
Placutele sunt noi
Discurile sunt noi
Probabil confunzi cu auto hold.
1. HDC e asistenta la coborare (se activeaza din buton)
2. Hill asist e asistenta la plecare din rampa, activa automat. Tii frana apasata, eliberezi frana si accelerezi. Sistemul intervine 2 secunde de la eliberarea franei. La mine functioneaza, automata cu xdrive.
3. Exista autohold pe e90?
doar cele cu xdrive stiu ca au aceasta optiune.
Faci confuzie intre asistenta la coborare (HDC) si asistenta la urcare
Chiar nu stie nimeni nimic despre asta ?
Detin si eu unul (E90) super bine dotat ....aproape ca zici star porno.....e tot manual dar nu are asa ceva.Cred ca faci ceva confuzii ....ai rabdare si o sa mai raspunda si alti colegi daca nu te-a multumit raspunsul colegului.Eu chiar nu stiu sa existe autohold pe E90......si oricum BMW-urile pleaca ca din pusca ,ce nevoie ar avea.frantics.giffrantics.gif
