Coduri FSC - NBT EVO
salut
am cautat si pe internet si pe alte forumuri dar nu am gasit o explicatie clara referitoare la punctele de mai jos:
1. care e diferenta intre 009F - TTS versus 016F - Speech TTS?
2. ce face mai exact 016E - Speech NLU?
3. ce este AppID 0170 - Component protection? Stiu ca e vorba de blocaj in caz de furt pt anumite Gxx. Este necesara activarea lui la Fxx?
4. Unitatea are bme connected drive activa cu internet si aplicatii gen vreme/flicker etc. desi nu are in VO original 6NR. la FSC status, AppID 9C apare ca not available desi pare-se ca merge. Este necesar sa ii pun un cod FSC si lui? Stiu ca exista 2 metode pt 9C - cod FSC sau provizionare?(provizionare banuiesc ca "vine" prin Internet-ul masinii via ATM direct din serverele BMW?
Ideea e daca merita sa schimb FSC-urile originale cu un full set custom.
multumesc
2. Da
3. "ISTA 4 and ISTA/P (BN2020)Introduction of component protection for Head Unit High 2
Benefit: To protect against theft, the Head Unit (HU-H2) of the specified vehicles with production date as ofNovember 2016 is coupled to the Body Domain Controller (BDC).
Vehicles: G11, G12, G30, F15, F16, F85, F86, F54, F60 as of 11/16 can be dealt with
Notes:
For the installation of a HU-H2 new part, the locking is performed automatically by ISTA 4 or ISTA/P.In the following cases the component protection must be activated in order that the navigation function worksproperly:
For a cross-exchange of a HU-H2,Technical Support must perform the locking.
In the case of a BDC exchange the lock must be performed by Technical Support.
Also see PuMA measure 62960142
New models with production dateBenefit: The new F52, F60, G30 can be dealt with.
Vehicles: F52, F60, G30"
4.unitatea a fost modificata manual ca sa mearga vremea, internet,etc / Pentru ce sa pui codul FSC??? daca o sa codezi default conform FA oricum nu va mai merge nimic... / cod FSC pentru vin validat.../vine si de la serverele BMW via sim integrat in nbt
Edited by zeronoo
Din ce ar parea, 9f 16f 16 e ar contine un algoritm mai avansat de procesare.
Unitatea este cea originala din fabrica. Nu e retrofit. Are totul activat mai putin pct 1,2 si carplay.
Si ma gandeam sa le activez cu un custom fsc set ca tot am tool ul de generat si nu ar costa nimic decat niste timp.
In cel mai rau caz, reflashuiesc unitatea si pun kitul de fsc repair original.
Da, pt CP am citit si eu notificarea din ista. Nu stiam ca pt deblocare trebuie fsc.
Sunt curios daca bmw apps va mai merge provizionat via atm fara fsc sau va trebui sa ii incarc fscul in 9c
Edited by Danyro
