P0174 & P0171
Sabah
Salutare, de ce nu incerci si o cautare pe Google? Uite ce am gasit eu asa la o prima strigare :
The P0171 code means that, on the first bank of the engine, the fuel system is running weak or a vacuum leak exists near this side of the engine. A lean condition occurs when the engine either receives too little fuel or too much air.
Error code P0174 is described as System Too Lean (Bank 2). This means there is incorrect ratio of air and fuel on the car's engine system, specifically on Bank 2 of the Cylinder. “Too Lean” means there is too much oxygen in the exhaust.
Bafta!
Edited by RedCap
