Eroare bujii E91
Am scanat cu Carly si am eroare pe 2 bujii desi de 2 saptamani am schimbat bujiile, mentionez ca releul nu l-am schimbat. Atasez niste loguri.
Carly for BMW - detailed Fault-Code Log
Found Faults:
--Engine / Motor--
*** 4212:Glow plug cylinder 1, control ***
Fault-Set 1 - ( 217040 km)
Air mass per cylinder: 516.73 mg/Hub
battery voltage: 14663.36 mV
Boost pressure actual value: 964.92 mbar
Coolant temperature: 5.95 deg C
Engine speed: 827.47 1/min
Injection quantity: 28.36 mg/Hub
Pedal value generator: 0.00 %
Rail Pressure Is: 370.22 bar
State of the glow indicator: 162.00 -
vehicle speed: 0.00 km/h
Fault-Set 2 - ( 217040 km)
Air mass per cylinder: 510.42 mg/Hub
battery voltage: 14826.28 mV
Boost pressure actual value: 1053.54 mbar
Coolant temperature: 60.16 deg C
Engine speed: 1075.72 1/min
Injection quantity: 18.12 mg/Hub
Pedal value generator: 15.75 %
Rail Pressure Is: 409.60 bar
State of the glow indicator: 0.00 -
vehicle speed: 13.82 km/h
*** 4222:Glow plug cylinder 2, control ***
