Coduri de eroare
egrimisu
Mi-am luat un Carly pentru diagnoza. Nu stiu prea multe doar ca a costat destul de mult mufa iar aplicatia pe iOS costa cam 60euro pe an fiind un fel de abonament.
Mi-am scanat masina un 420xd 190ch 2016 iar erorile gasite sunt mai jos. Nu sunt in masura sa le interpretez deci as dori opina voastra. E de rau gagiilor?
Engine / Motor
Fault Code: 284E00
Fault Explanation:Lambda probe according Kat, Nernst
voltage signal: Interruption
Air conditioning / Klimaanlage
Fault Code: 8011F9
Fault Explanation:PTC module: reducing heat output for
Power Management
Integrated Chassis Management Quer/Längsdynamik
Fault Code: 480134
Fault Explanation:SBS function - direction unsure vx
greater than 2 m / s
ICAM - Rundumsicht + RĂźckfahrkamera als
Standalone System
Fault Code: 800BAA
Fault Explanation::Composite Output: open or not
connected / Error in composite output, not connnected
Central Gateway / zentrales Gateway
Fault Code: CD0487
Fault Explanation::Synchronization process failed, CC
was not in sync with the date of repeal of error Memory
Lock / FLEXRAY StartUpFailed
Anti-Blockier-und Stability Control 5 auto. E34 / 16
Fault Code: 801A55
Fault Explanation::Disconnection of loads due to
overtemperature / Car alarm: Alarm - details in the alarm
memory
Advanced Telematic Module
Fault Code: 03178A
Fault Explanation::SIF: General Mobile network error
