X1 23d E84
alex230ro
A "resoftat" cineva cutia 6HP19 ? mai exact cu cei de la https://www.xhpflashtool.com/en/ vad ca au si prin Romania dealeri.
As mai vrea sa adaug o izolatie la capota de fabrica se pare ca nu gasim asa ceva , totusi vazusem undeva un cod pentru izolatia pe original.Daca stie cineva mai multe poate imi spune si mie.
Cutia merge mult mai ok, inca trebuie sa ma obisnuiesc cu ea, in D schimba cam lent din punctul meu de vedere si tine motorul prea subturat, daca ar fi dupa mine in DS as merge tot timpul. as incerca de mai sus cu comentariile
Stage 1
This Stage 1 file helps, to cure a lot of the issues, the N47 engine is suffering from, when paired with an Automatic transmission. Your Torque Converter clutch will now grab immediately after lift of in 1st Gear. This helps economy and get's rid of the "rubber-band" feeling, when accelerating from a stop. Shift Points are changed in all modes, to give you a more lively driving experience and to help disguising the Turbo-Lag in the lower rev range. In manual mode, you will notice 50% shorter shift times and quicker, rev-matched downshifts. You will love to drive in manual mode in the future.
Current Version: V1.0
Version: V1.0
- Gear Display in Dash in all Modes (D1..D6, S1..S6, M1..M6)
- Reworked shiftmaps in all modes. (D/S/M, Uphill, Downhill driving)
- Torque Converter Clutch closes immediately after lift off in 1st gear
- Quicker shifts overall, while retaining full factory smoothness
- Raised Auto-Shift RPM in D (4300), S (4500) and M (4900) - aici as lasa D-ul la 2800 3000 rpm
- Slightly raised minimum RPM in 5th/6th gear to reduce engine/drivetrain drone
- 50% faster shift times on all shifts in Manual mode (400 ms -> 200 ms)
- Rev - Matched (Throttle Blip) downshifts in Manual Mode
- Removed stock TQ Limit (Stock Limit: 465 Nm) - NU
- True Manual mode (no-upshift at Redline in M Mode) - NU
in ce zic ei eu cel mai mult am sesizat "rubber-band" feeling, when accelerating from a stop.
Mai studiez :)
  • 3 months later...
Bun as vrea sa fac:
- curĂŁțare admisie
- schimb ulei cutie transfer
Recomandari unde as putea face asta?
Pe lista ar urma
-retrofit cruise control
-soft cutie automata,am gĂŁsit un coleg care lucreazĂŁ cu xhp iar prețul e ok.
Ăntre timp am verificat și cutia cu cei de la Automatico cĂŁ sa fiu eu liniștit ,totul e ok.
Edited by alex230ro
Discuri si placute fata si placute spate schimbate saptamana trecuta.
Luna viitoare ajung si la tampoane soft cutie, apoi revopsit capota, spoiler= ciuruite de pietre si o usa zgariata/infundata.
Resetat duminica trecuta consumul - pe bord zice 8.9 daca nu ma insel , trafic mixt dn1 si oras plus dimineata vreo 10-15 min stat pe loc :) acceptabil in aceleasi conditii 2.5ul se ducea catre 11.5
edit - si cruise control ar mai fi pe lista dar pare greu de gasit
Edited by alex230ro
-Tinuta de drum - nu stiu ce sa zic inca mai ne cunoastem masina se inclina destul de mult in viraje dar paradoxal este rigida
Am venit cu a unui prieten din Germania, si paradoxal, mi s-a parut ca statea neasteptat de bine in curbe la viteza mare. Ce-i drept avea suspensie sport a lui, tu ai normala
ma gandesc ?
ma gandesc ?
Pai odata suspensie normala- cred, apoi cauciucuri normale. Ar mai fi de mentionat ca am comparat cu masina avuta inainte care avea suspensie sport de fabrica plus bari intre amortizoare fata si spate.Cu masina merge un general sotia iar ea s-a declarat foarte multumita de comportamentul masinii.
@Saylor Man, nu pot deschide linkul dar oricum m-am obisnuit/resemnat cu zgomotul si vibratiile motorului
Asta pe care am condus-o avea suspensie sport dar cauciucuri normale, in oras se simtea cam ca a mea sau poate chiar putin mai soft (G30 cu suspensie normala si runflats) la denivelari. Oricum
m-a impresionat X1-ul cat de bine statea pe drum, am adus-o pe vreme proasta, vant, ploaie, mazga pe jos si s-a comportat foarte bine, nu iti da senzatia de "suv".
  • 6 months later...
Bun, a atins sotia usor o alta masina, avand un CASCO facut (cel de la City Insurance casco la pret de RCA) am mers am declarat ,cei de acolo au dat:
- indreptare capota fata
- schimbare ceva ornament bara plus revopsite bara
apoi mi-au dat lista asta https://cityinsurance.ro/wp-content/uploads/2019/06/Lista_unitati_reparatoare_partenere.pdf
A avut cineva experiente cu serviceurile de pe lista? sunt obligat sa repar numai la acele serviceuri masina(din ce tin eu minte nu)
