MYX 6 --F10 530 XD
Myx
Azi am apasat butonul SOS de curiozitate sa vad ce face si dupa cateva secunde am auzit 112 Ce urgenta aveti , evident am ramas masca am spus ca ma joc la butoane si am apelat gresit , dra mi-a urat o seara buna si la revedere :))))). M-am uitat la telefon si nu era conectat pt ca nu am apelul deci masina are un sim undeva si stie sa sune la 112 . E vreun pachet platit undeva , unde pot afla despre ce e vb . pe ecran afisa apelul si pozitia masinii long si lat Edited by Myx
Normal ca masina are SIM - adica ceva de genul - cum ar merge serviciile Connected drive altfel ? Mai interesant ca apelul este rutat catre serviciile noastre de urgenta, adica din Romania . Sau poate masina a fost cumparata de noua din tara ?
stiu ca are sim dar la multi nu e functional si as vrea sa aflu unde cum se plateste ca sa ramana asa , imi pare f util serviciul in caz de urgenta sa ai linie directa 112
Toate masinile care au ConnectedDrive in navigatie au aceasta optiune gratis.
BMW Assist (SOS) Emergency Call
After pressing the SOS button, your vehicle's location and other important data are transmitted to the BMW Assist Response Centre. A response specialist will speak with you to coordinate dispatch, notify your emergency contacts, and link you to BMW Roadside Assistance* as needed/requested. Emergency directions may also be provided.
If an airbag is deployed, BMW Assist Emergency Call automatically contacts the BMW Call Centre via an accident-proof telephone unit permanently installed in your vehicle. Specially trained personnel will then establish contact with you and inform emergency services.
The same connection simultaneously transfers the position of the vehicle to the nearest metre together, as well as data relevant to the rescue services, such as risk of injury, number of passengers, model and colour of the vehicle. The emergency call can also be triggered manually, such as if you need to summon assistance for other road users.
Edited by Stormzor
Si unde este locatia sim ului?
Nu e un SIM efectiv - e un modul care comunica prin GSM cu serverele BMW sau serviciile de urgenta.
@Myx "SIM-ul" nu este inactiv - probabil doar serviciile BMW sunt dezactivate pt modelele mai vechi (cu CIC), din cauza ca viteza este prea mica - doar 2G . El functioneaza insa pt serviciile de urgenta, cum a explicat Stormzor si mai te spioneaza putin transmitand anumite date catre serverele BMW.
Edited by seaman
welcome to the 3.0L club :thumbsup: . Ma bucur ca ai ales sa incerci motorul asta, banuiesc ca esti foarte multumit de masina in combinatia cu motorizarea pe masura ei?! Sa te bucuri de ea ca ea se va bucura cu siguranta de atentia pe care i-o acorzi :goodjob:
multumesc , Da motorizarea chiar face diferenta , desi ma gandeam ca e inutila in oras , se comporta f bine , simt ca tasneste de pe loc si fiind xdrive o controlezi f usor , nu stiu 2.0 sau 2.5 cum e , probabil ca la drum lung se simte diferenta mai intens in oras posibil sa fie toate la fel cu avantaj motoarele mai mici la consum . Intre timp evident ca ma tenteaza sa schimb jantele pt ca nu imi plac actualele deloc . Momentan asta am gasit si ar fi setupul de iarna cu style 408M et25 toate rotile , imi pare ca arata ok , poate pe spate ar merge distantiere , asta ar fi oferta de pe olx.pl , mi-a trimis poza cu ele montate .Masina pe care sunt montate e tot xdrive , am o mare teama sa le iau de la un vanzator din polonia chiar daca pare unul serios .Anvelopele sunt noi , iarna , rft . Ma mai gandesc
http://i936.photobucket.com/albums/ad206/tnt221/image_2_zpsygzydeon.jpg
http://i936.photobucket.com/albums/ad206/tnt221/image_0_zpsf1hiasat.jpg
Edited by Myx
Nu lua jante pe 18-19 cu anvelope runflat, o sa faca cam urat pe drumurile noastre.Nu exista termen de comparatie intre motor 2.0 cu 3.0 inainte am avut f10 2.0, acum 3.0. 3.0 este mult mai bine echilibrat, nu vibreaza, nu face nici cum urat, se aude foarte frumos, nu mai zic de cum trage. Edited by branevl
Eu am avut de a lungul timpului pe bmw si anvelope runflat si normale. Ce pot sa spun dupa zeci de mii de km este ca daca producatorul a pus runflat pe masina nu a pus degeaba. Suspensia este setata pt cauciucurile respective. Cum pui normale cum masina nu mai e la fel de stabila.
Am si eu runflat pe 17 de iarna si 18 normale de vara stiu cum e diferenta si eu o vad doar in rau cu runflat, eu nu as mai pune nicicum runflat.Daca pui anvelope normale bune o sa fie stabila, sa nu aiba peretii laterali foarte moi.O diferenta exista bineinteles, dar la jante mari nu se mai simte prea mult. La jante pe 19 talonul este destul de mic... Edited by branevl
  • Like 3
nu am sa inteleg niciodata problemele astea pe care le avem cu totii si anume ca daca nu avem roti de 19 sau 20 si musai runflat+EDC si alte chestii, masina nu e stabila, insa vezi vw jetta depasind lamborghini gallardo pe valea oltului.
orice masina este atat de stabila in functie de cat este capabil soferul. punct. iar asta e axioma.
orice curba pe care noi o facem cu 100kmh cu roti de 20 si runflat, masina este capabila sa o faca cu 120 purtand 225/55r17 fara runflat
Edited by edit
  • Downvote 4
Aici se refera cat de mult se inclina masina intr-o curba,deoarece seria 5 este o masina destul de grea,niciodata nu o sa se comporte ca un golf sau jetta,pana la urma este o masina confortabila cu inclinatii sportive,confirm in privinta cauciucurilor run flat,din cauza peretilor laterali mai tari masina nu se inclina atat de tare ca unele normale fiind mai moi,probabil cu Michelin Pilot Super Sport 4 XL fiind mai tari sunt similare celor run flat.
cavaliere, exact asta incercam sa spun.
plus ca suntem prea muieri(cu mine in frunte) ca sa avem curajul sa intram in curbe la nivelul potentialului pe care il are o masina si sa acuzam ca nu sunt 20 de inch, run flat, PS4, EDC, bare stabilizatoare hidraulic, ca altfel, soferul ar fi putut face curba cu 5kmh in plus
Edited by edit
