Cuplare automata frana de parcare electronica
Salutare tuturor,
sunt proaspat posesor de X1 F48 20dXdrive. Am o problema cu frana de parcare electronica, in sensul ca odata ce am parcat masina, pun selectorul cutiei de viteze in P, opresc motorul, scot centura (in orice ordine sau conteaza fiecare pas?) frana de stationare nu se cupleaza automat. Cu alte cuvinte trebuie sa o actionez/cuplez eu de fiecare data, desi corect (asa cum am la cealalta masina) ar fi sa se cupleze automat, odata ce am scos centura sau macar cand deschid usa.
La voi cum este? Se cupleaza automat? Trebuie facuta vreo setare, ceva?
De decuplat este ok, functioneaza corect: in momentul cand calc acceleratia se dezactiveaza si frana, cu masina in D/R.
Multumesc!
Salutare tuturor,
Multumesc!
De ce spui ca este corect sa se cupleze automat? Scrie in manual? Eu o cuplez singur intotdeauna asa ca nu am observat ca nu se cupleaza automat, dar am verificat acum in manualul masinii (F15) si nu scrie nicaieri ca ar trebui sa se actioneze automat. De decuplat, scrie clar ca se decupleaza automat (desi nici asta nu fac niciodata).
Edited by mkdan2004
Nici la MB nu este chiar asa. Uite din manualul de la ML W166 (ultima generatie):
The electric parking brake is applied automatically:
- if DISTRONIC PLUS brings the vehicle to a standstill or
- if the HOLD function is keeping the vehicle stationary
In addition, at least one of the following conditions must be fulfilled:
- the engine is switched off.
- the driver's door is open and the seat belt is not fastened.
- the vehicle is stationary for a lengthy period
P.S. Acum am gasit si la X5 (era la sectiunea auto-hold):
Parking The parking brake is automatically set if the engine is switched off while the vehicle is being held by Automatic Hold. The indicator lamp changes from green to red. The parking brake is not set if the engine is switched off while the vehicle is coasting to a halt. Automatic Hold is deactivated. Automatic Hold remains activated during the engine stop brought about by the Auto Start/ Stop function.
Edited by mkdan2004
Probabil ca activarea automata sa fie in legatura cu functia de AutoHold, ceea ce le F48/F49 (seria 2) lipseste cu desavarsire. Posibil sa se activeze automat, asa cum scria un coleg mai sus, in caz de panta/rampa - parca asa citisem si prin manualul de utilizare, dar nu am experimentat niciodata asa ceva.
  • 6 months later...
Confirm ca si la F48 frana de stationare electrica se cupleaza automat atunci cand masina simte ca este pe o suprafata inclinata. Si totodata am putut observa ca are si un autohold care se face prin circuitul de franare de serviciu, pentru 3-4 secunde.
opreste masina in rampa daca ai oprit complet din frana , atunci intervine si o tine oprita , daca o tii mergand usor nu va interveni decat daca are autohold activat, am testat eu ambele variante , credeam ca fara autohold nu face treaba dar si la E60 era la fel , in rampa o tinea cateva secunde si aveam piciorul ridicat de pe frana, probabil exact cat sa-ti dea timp sa accelerezi iar , cred ca 5-6 sec erau la E60 si trebuia sa apas iar frana si reseta timpul , la f10 n-am cronometrat dar o sa fac un test cu timpul , e bine de stiut
Edited by Myx
  • 4 years later...
