246B00 : Charge-air pressure sensor, signal: plausibility with ambient-pressure sensor at idle
Fault description
Plausibility check of charging pressure with ambient pressure. The fault is detected if the difference between the charging pressure and the ambient pressure exceeds a limit value.
Limit value: 300 mbar
Condition for fault identification
Monitoring takes place when the following preconditions are met:
- No electrical fault is stored for the ambient pressure sensor and charging pressure sensor.
- The engine speed is below the following value: 750 rpm.
Control unit voltage: 9.5 V to 16 V.
Condition for fault memory entry
The fault is entered if it is present for longer than the following period (debounce time): 10000 ms
Action in service
1. Check the plausibility of the measured values of both sensors.
2. Check line and plug connections
3. Check the voltage supply of the sensors (contact resistances falsify the measured value).
4. Continue troubleshooting at the sensor with the implausible measured values.
Fault effect and breakdown warning
None
Driver information
None
Service instruction
Check the plug connections, lines and voltage supply of the charging pressure sensor. Contact resistors can falsify the charging pressure value.
Edited by neo_andersson
250A00 : Rail-pressure sensor, signal : short circuit to ground
Fault description
Rail pressure monitoring. The fault is set if the non-linearised value of the rail pressure sensor (voltage) is less than the limit value.
Limit value: 131 mV
Monitoring takes place every 10 ms if no fault relating to the supply voltage of the rail pressure sensor is logged.
The fault is entered if it is present for longer than the following period (debounce time): 140 ms
Action in service 1.
- Check connections for corrosion!
- Check connectors for correct locking!
2. Carry out function check.
If checks mentioned above are OK: Replace rail pressure sensor.
The fault blocks regeneration of the diesel particulate filter.
Visit your nearest BMW Service Centre.
Driver information
CC message
Service instruction
If the rail pressure sensor was renewed, the following service function must be performed: Delete adaptations, fuel system.
