Enhanced bluetooth f30
Da, se activeaza prin codare. Este extrem de overpriced varianta dela bimmertech, la fel ca tot ce ofera de altfel.
Poti sa codezi si singur:
HU_CICHB > AUDIO_TUNER_TRAFFIC 3002 > AUDIO_OFFSET = aktiv
HU_CICHB > HMI 3000 > CDMM_AUX_HU = nicht_aktiv
HU_CICHB > HMI 3000 > CDMM_USB_COVER_ART = aktiv
HU_CICHB > HMI 3000 > SECONDARY_HFP = aktiv
HU_CICHB > HMI 3000 > SVS = aktiv
HU_CICHB > HMI 3000 > SYSTEM_TTS = aktiv
HU_CICHB > SYSTEM_EINSTELLUNGEN 3004 > SOFTWARE_UPDATE_ASSISTANT = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > ADRESSBOOK = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > API_TYPE = combox
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > BT_PHONE_INSTANCE_ID = wert_2
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_BLUETOOTH_AUDIO = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_AUDIO_DOUBLE = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_AUDIO_SINGLE = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_COMPOSER_IPOD = enabled
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_COMPOSER_MTP = enabled
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_HMI = new
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_POD_BOOK = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CONNECTIVITY_SYSTEM_VER = ecu_sw_vid
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > DATACOM_INTERFACE = combox
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > DATACOM_TRANSFER = mamac
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > EXTERNAL_CALL_LISTS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > FUNCTIONALITY_VIEWER = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > HDD_ACCESS_VIA_ETHERNET = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MACRO_PIM = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MESSAGE_FILTER = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MIC_OVER_MOST = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MICROPHONE = no_microphone [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MUTE_BUTTON = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > NAD_PHONE_INSTANCE_ID = wert_1
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > ONLINE_BROWSER = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_ALL_INC_CALLS_LIST = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_CONFERENCE_CALL = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_MPC = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_OBJPUSH_MENUE = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_RESPONSE_HOLD = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_SMS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_TYPE = combox
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONEBOOK_CACHING = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PICTURE_ALBUM_ARTS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PIM_CROSS_USE = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PIM_TTS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > SINGLE_OR_MULTILINK = multilink
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > TDA_TSR_INSTANCE_ID = 0x0 [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > TELEMATIC_INSTANCE_ID = instanceid_ 0x01
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > VCARD_OVER_MOST = aktiv
Combox_Media > BLUETOOTH_PARAMETER 3004 > A2DP_AVRCP_EIN_AUS = aktiv
Combox_Media > BLUETOOTH_PARAMETER 3004 > BT_EIN_AUS = aktiv
Combox_Media > GENERAL_PARAMETER 3000 > MAIN_BOARD_ALONE = ecallboard_present
Combox_Media > MULTIMEDIA_PARAMETER 3003 > API_EIN_AUS = aktiv
Combox_Media > SWUP_PARAMETER 3005 > SWUP_ENABLE_SW_UPDATES = aktiv
Combox_Media > SWUP_PARAMETER 3005 > SWUP_SOURCE_ONLINE = nicht_aktiv [Default]
Combox_Media > SWUP_PARAMETER 3005 > SWUP_SOURCE_USBMSCDD = aktiv
Combox_Media > TELEMATIK 3006 > GPS_FROM_MOST = nicht_aktiv [Default]
Combox_Media > TELEMATIK 3006 > TDA_TSM_ACTIVE = nicht_aktiv [Default]
  • Downvote 2
Multumesc! Intr-adevar nu e ieftin, dar avand in vedere ca cineva in Iasi mi-a cerut 400 EUR (solicita si achizitia unui Combox neaparat) pt aceeasi treaba, am zis ca e bun si asa.
Eu sunt novice in treaba asta, dar se poate face cu aplicatia BimmerCode+OBD?
Edited by Legacy
...si unde ar trebui sa codeze liniile astea din moment ce el nu are combox?
Edited by zeronoo
Update
Pana la urma am verificat daca am Combox in masina si cu stupoare constat ca am. Pe cine intrebasem initial cum verific, mi-a zis sa ma uit in dreapta portbagajului, deasupra rotii.
Long story short, datorita ignorantei mele am pierdut o gramada de timp pt solutii activare Enhanced Bt fĂŁrĂŁ Combox.
Acum, ce program Pc/ aplicatie tel recomandati pt codare?
