Recall BMW E90 0061830500 cablaj + conectori ventilator aeroterma/aer conditionat
cataliin93
Salutare colegi!
A aparut de putin timp un recall pentru cablu + conector + modul ventilator BMW E90. Eu am verificat-o pe a mea si imi apare, asa ca satamana viitoare sunt programat la BMW Cobalcescu Pitesti. Va anunt cat dureaza si ce au schimbat :)
Pentru verificare am folosit site-ul https://www.bmw.co.uk/en/footer/quick-links/bmw-vehicle-recalls.html
Stire romana: BMW a anuntat ca in scurt timp incepe o campanie de rechemare a peste 430.000 de masini Seria 3 care au probleme cu sistemul electric. Germanii au descoperit ca sunt sanse de incendiu pentru aceasta generatie de masini Seria 3, si pentru a nu avea probleme cu autoritatiile KBA vor schimba gratuit in unitatile service BMW piesele care sufera. Rechemarile BMW au urmatoarele coduri: 0061830500”, “0061660400” si “0061830400, iar elementele care se schimba sunt reprezentate de cablaje si contactori care au imbatrinit necorspunzator si care pot duce la aparitita unui incendiu. Intreaga operatiune are un timp de lucru de 60 minute si se efectueaza gratuit de catre reprezentantele BMW din toate tarile din UE!
Stire engleza: Risk of fire with half a million older BMW 3-Series (E90 – E93). The warning about the increased risk of fire with the BMW 3-Series has been known since the end of 2017. A recall has already taken place in some markets, but only at the end of January did it start in Germany. About 430,000 owners of the BMW E90 to E93 model series must visit authorized services.
The recall concerns vehicles manufactured between July 2004 and June 2012. The plug connection from the wiring harness to the heating and air conditioning system’s fan regulator could overheat due to fretting corrosion. Possible consequences are a short circuit, melting of the connector or “in very rare cases” a “thermal issue” – even when the vehicle is parked.
Din ce am citit de pe forumul de e90
"the callback is for the wiring from the fan controller.
"Check E9x plug connection, fan controller, rework if necessary (Part III)" Provides
3x different procedures, depending on the "damage"
1. Shortly install repair cable (5-7 AW)
2. Short repair cable and replace fan controller (6 - 8 AW)
3. Install a long repair cable and replace the
fan controller (18-20 AW) The fan controller is also often called a hedgehog or fan output stage. It can happen that the cable starts to scorch at the plug to the fan controller, which can lead to a cable or vehicle fire.
Edited by cataliin93
Revin cu mici detalii de la rechemare...
Am fost ieri la rechemare eu cu E91 320d + un prieten cu E91 320i. Am bagat masinile in service, la mine a durat aprox 1h, la el aprox 1.5h iar la final ni s-a spus ca este necesara schimbarea cablajului la amandoi dar ca nu au cablul pe stoc. O sa fim sunati de ei cand o sa primeasca piesa.
Partea proasta:
* ma asteptam sa aiba si ei un stoc tampon de 4-5buc de cablaj din moment ce este rechemare foarte mare + facusem programarea de sapt trecuta specific pentru cablaj
* seara cand am plecat spre casa am constat ca masina nu baga deloc caldura indiferent cum reglam intensitatea aerotermei...asadar au uitat sa bage ceva cablu de la aeroterma cel mai probabil :(
Asadar cand plecati de acolo, verificati sa mearga aeroterma de la caldura, indiferent daca au schimbat sau nu cablajul.
Nu au stres :) piesele vin din Germania si nu le tine pe stoc nimeni, ex la moto mi-a crapat alternatorul - desi e o problema cunoscuta se pare ca in Germania erau pe stoc fix 2 buc, iar cei de la service au zis ca au lansat comanda dar ca nu garanteaza ca "prind "piesa . Discutia a fost : buna ziua alternatorul e ars am facut comanda in Germania pe stoc sunt 2 bucati ar trebui sa ajunga in 5-7 zile lucratoare dar nu garantam ,daca nu il "prindem" e posibil sa asteptati pana la o luna :) . Edited by alex230ro
