Inversare borne baterie
Ca sa bag batzul prin gard putin...1st things 1st: Bendix este denumirea unei marci producatoare (de to felul) care a inventat tot felul de treburi in automotive printre care si electromotorul auto, sa numesti un reper "bendix" este ceva similar cu "adidasi", "webasto", etc asa ca cred ca e destul de greu sa stabilesti ce piesa sau ansamblu "e bendix"...e doar o denumire populara
  • De acord! 1
  • Hot!! 1
Eu am infierbantat topicul asa ca tot eu ma vad indreptatit sa zic ca.. ma tem ca, de fapt cineva a luat termenul si si-a facut reputatie pe un termen tehnic. 😉
Pana una alta,
https://www.pieseauto.ro/electromotor/pariu-ca-nu-stiai-cum-functioneaza-electromotorul-masinii-tale-30.htm
A existat un american care l-a inventat:
https://en.m.wikipedia.org/wiki/Bendix_drive
Completez si eu: "In 1907 Vincent Bendix founded the Bendix Corporation of Chicago to manufacture automobiles, called Bendix Motor Buggies. After two years and producing 7,000 vehicles the company failed. In 1910 however, Bendix invented and patented the Bendix drive, a gear that could engage an engine at zero rotational speed and then (through the aid of a spring and the higher speed of the running engine) pull back and disengage automatically at higher speed (nominally the engine's running speed). This drive made the electric starter practical for automobile engines and later for engines in aircraft and other motorized vehicles."
destept omul...
Edited by zeronoo
On 1/12/2022 at 8:12 PM, 13NCU said:
Da, da ☺️
...din acest motiv nu tractez necunoscuti si nici nu imprumut curent. Nu e rea vointa, in general ajut cat pot ...dar uite, asta e genul de caz cand ramai sportiv in pantaloni scurti langa masina ta in timp ce "ala" pleaca.
Da, in cazuri "speciale" (in familie/prieteni apropiati) imprumut curent dar eu manevrez cablurile. Si nu e recomandat decat a se folosi STAS-uri, adica acel cablu rosu-negru din comert unde nu prea ai cum sa confunzi lucrurile.
Regula de aur - masina donatoare sa aiba motorul oprit atunci cand masina primitoare incearca sa porneasca.
Asta pt mentinerea sanatatii releului de incarcare propriu.
Da, am patit si eu acum ceva ani cu un taranush la vulcanizare, basinos. Aveam benzina 1,3 și marlanu avea opel 1,9 diesel fara baterie, muci. a pus cablurile a pornit harbul lui de jaf iar eu la o zi sau 2 aflu ca "m-a lăsat în pantaloni scurti", mi-a foot releul de încărcare.
Bateria mea era un rombat premier verde 65ah atunci.
Alta data un magar sa nu zic altfel, la un  parc de vanzari auto sh neinmatriculate, ramasese cu cacatul de masina a lui fără baterie, ceva Corsa 1,2. Traversase nesimțitul strada sa ma roage sa scot bateria de pe mașina mea, sa isi pornească jegul masina lui.
Am zis ca in viata mea nu mai ajut pe nimeni cu dat curent de la mine.
Bună seara
13NCU...nu am cerut curent, am dat de la BMW la o alta masina a mea.
Azi am  pornit împins BMW-ul pentru...a pornit imediat însă martorul de la baterie era aprins. Am dat electromotorul și alternatorul jos. Am desfăcut electromotorul, cărbunii sunt buni, l-am pus pe baterie și a pornit, deci electromotorul este bun. Am desfăcut alternatorul, puntea de diode pare bună, o sa înlocuiesc alternatorul însă dilema mea este ca, sa zicem ca alternatorul este mort, tot trebuia sa o ia electromotorul. Păreri??
Edited by Poianamare
On 1/12/2022 at 9:35 PM, Poianamare said:
 Mi-am dat mie curent la alta mașină, mai dădusem de "n" ori, ști exact ce trebuia sa fac numai ca, din cauza grabei, ploii, dar mai presus A PROSTIEI, am inversat cablurile.
Offf ...in final, cu BMW-ul din discutie, al DAT curent sau ai incercat SA IEI ?
Chiar cu alternator mort, daca bateria e in stare buna, ar trebui sa porneasca si sa mearga x minute dupa care se opreste. Daca ai martorul baterie aprins, e clar, releul nu a supravietuit.
Faza cu electromotorul nu e relevanta. Am patit si eu ca la conectare pe borne baterie functiona de-mi sarea din mana ...dar montat pe motor nu avea putere.
PS
- acum 3 zile, Fiat Grande Punto, nepornit de 6 luni.
Cheie, o ia, apare martor baterie (ignor), mai apare un "volan" pe bord (ignor), motorul mergea ...dupa 3 minute s-a oprit brusc.
Incerc sa pornesc, electromotorul nu are viata, dau curent de la BMW, porneste, dupa 5 minute moare.
Am inlocuit alternatorul, am incarcat bateria, totul ok.
Edited by 13NCU
  • Confused 1
REZOLVARE:
Aviz celor care o pățesc.... Pe borna de + care pleacă de la baterie, pleacă doua fire. Se pare ca acolo este o "capsa" care în caz de accident, probabil și în caz în care cineva face ceea ce am făcut eu, declanșează și "rupe" unul dintre fire pentru a nu lua foc autoturismul. Asta s-a întâmplat la mine.
După ce am montat alternatorul și electromotorul " care se fapt erau bune însă am schimbat releul de încărcare și rulmenții de la alternator", am dat o gaură prin acel fir, am băgat un autofiletant și am rezolvat problema. 🙂🙂
Mulțumesc celor care au trimis mesaje pentru a ma ajuta și a rezolva problema. Toate cele bune va doresc!
  • De acord! 1
"Mulțumesc celor care au trimis mesaje pentru a ma ajuta și a rezolva problema. Toate cele bune va doresc! "
Bine primit.
Pai nu ti-am zis sa verifici toate sigurantele pe langa baterie? 😉
Sunt curios care a fost procesul pana ai constatat capsa pirotehnica sarita. Tu insuti ai gasit-o sau altcineva?
Multumim ca ai revenit cu rezolvarea.
  • De acord! 1
Eu am verificat siguranțele, de acea capsa nu aveam nici cea mai mica idee. După ce am montat alternatorul și electromotorul, le-am exclus după lista și atunci am chemat un electrician cu un aparat de măsură care a descoperit problema în 5 minute. Partea buna este ca am făcut alternatorul ca nou🙂🙂🙂🙂
