Martor ulei aprins e46
Vă salut, am o problema la un e46 320cd 2004 , dupa ce opresc motorul mi se aprinde martorul galben in bord si ramane aprins si daca scot cheia din contact si inchid masina cu cheia , ramane cam 20 sec aprins, sa fie slaba calitatea uleiului? Am facut momentan 9700km urmeaza in 300km sa schimb filtrele si uleiul.
Salut, te anunta ca ai pierdut ceva ulei < de 1/4, verifica pe joja cat ulei mai ai, ar trebui sa fii ok inca 300 de km.
Cam asa functioneaza senzorul de ulei :
Red - Low oil pressure. Should be on with engine off. If it stays on for more than a second or so after startup, or if it comes on while driving, shut off engine NOW!
Yellow; on after shutting off car - A little low on oil. Add oil soon
Yellow; on while driving - Significantly low on oil. Add ASAP!
Yellow; on for about 15 second right after startup - Defective oil level sensor. Check oil level manually and replace sensor at next oil change.
Edited by Mihai F
  • Thanks 1
