801222 air conditioning compressor
Salut, ce reprezintă mai exact eroarea de mai jos:
801222 Air conditioning compressor: switch-off due to missing dmr/dde release
O primesc din când în când pe tester.
Un prieten mi-a zis că e normal, apare la multe mașini, nu e nimic grav, să zic așa.
Edited by redog4dy
  • redog4dy changed the title to 801222 air conditioning compressor
801222 - Air conditioning compressor: switch off due to missing DDE/DME release
No other symptoms, and that's not even a fault - it's an info event. But I'm anal about these things, so it was quite annoying.
Normally, this fault indicates that DDE/DME did not allow the AC compressor to run because of engine load - temperature conditions, etc. In my case, I was getting this error even with a cold engine start, so the description didn't make any sense. I did a lot of googling but no solution - many people say it's normal, many cars have it, etc.
I think I fixed it, at least in my case 😉 I was having nothing better to do, so I was browsing through TIS and noticed that after IHKA programming/encoding the Steering Wheel Normalization ABL has to be executed. What does IHKA have to do with the steering wheel you may ask? No idea. Did I program/encode IHKA via e-Sys, thus not running the post operations ISTA would? Yes I did. So, i ran the service function and no error for more than a week now! Thus, I am 99% sure it's fixed, as I was getting the fault instantly before.
Salut, poate ajuta asta....
  • Thanks 1
Hmm, nu am înțeles tot, dar mi-am codat cu esys, memory on la aer condiționat, să păstreze memoria, să pornească cum îl las ultima oară, o fi de la asta?
De vreo lună primesc și o eroare că trebuie să completez cu freon. Dar în perioada asta nu prea am folosit compresorul. Decât aerul de la motor. Urmează să bag și freon. Aveți idee cât intră în f10?
Edited by redog4dy
Intra cat scrie pe eticheta daca este gol complet, altfel vei vedea cand pui robotul.
Edited by Ali
  • Thanks 1
2 minutes ago, redog4dy said:
Și e ceva nasol, sau nu are treabă? Mă refer la eroare.. 🤷🏾‍♂️
E doar o atentionare, nu este eroare. Calculatorul DME DDE nu lasa compresorul de clima sa porneasca din cauza unei anumite situatii gen load prea mare sau o temperatura crescuta a mediului sau motorului la un anumit moment dat. Tipul de pe forum zicea ca a citit in TIS ca dupa codarea sau programarea computerului IHkA pe care el a facut-o trebuia sa ruleze procedura Steering Wheel Normalization ABL si dupa ce a facut asta eroarea a disparut.
Spor la treaba!
  • Thanks 1
