Stergatoare ramase sus
Salut.
O mica problema ciudata la un e46 320d din 2000. Stergatoarele au ramas sus (mod service). Ele functioneaza doar ca la oprire nu ramane jos la capota ci pur si simplu se duc sus pentru finalul cursei.
Am incercat sa opresc motorul ca stergatorul jos dar degeaba ca cand le pornesc tot revin sus.
Ma puteti ajuta cu un sfat?
@DinuR cred ca va trebui sa dai motorasul jos, sa-l desfaci si sa cureti discul din el. Daca nu se rezolva, atunci cred ca va trebui inlocuit.
https://www.e46fanatics.com/threads/diy-windshield-wiper-motor-replacement.704507/
"Low and behold the disc inside was covered in grease. I took a rag and wiped all the grease off the disc (first picture below) and the two little brushes (2nd pic below circled in red) that contact the disc. I reassembled the motor, plugged it back into the car to see if it worked, and what do you know, it works like new. So before buying a brand new motor, open your existing motor up and give it a good cleaning and see if that solves your problem. It can also solve the problem of having your wipers stop halfway across your windshield."
Edited by Edwin
