Manual de service TIS la F10
2 hours ago, Sorin_87 said:
Salut
Vreau sa inlocuiesc ambreiajul la un F10 B47 si as dori sa ma ajutati cu un workshop manual(TIS), daca are cineva.
Ma intereseaza cuplurile de strangere si codul piesei de centrare ambreiaj.
Din pacate newtis a fost inchis.😮‍💨
Multumesc anticipat.
11 22 Flywheel
Tightening Torques
  Type Thread Tightening specifications Torque
1AZ Flywheel to crankshaft
B47O0 M12x1.5 Replace screws. 120 Nm
1VnXo6cNTV
Manual gearbox.
Secure flywheel with Torx screw (1) and special tools 11 9 811 and 11 9 265 .
Release flywheel bolts using special tool 11 4 180 .
1VnYIr6cwY
Automatic transmission.
Secure flywheel with transmission bolt (1) and special tool 11 9 811 /11 9 265 .
Unfasten flywheel bolts.
1VnXQFZYDa INSTALLATION:
1Vnc6wsArH
Manual gearbox.
Position flywheel (B).
Renew flywheel bolts (1) to (8).
Parts: Flywheel bolts
Fit new flywheel bolts with the special tool 0 491 018 (11 4 180) by hand.
Make sure that the tightening sequence from dowel pin (A) is followed.
1VnXo6cNTV
Tighten flywheel bolts with special tool 11 4 180 (adhere to angle of rotation in the next work step).
Tightening torque: 11 22 1AZ.
1Vnh31c7GO
Mark all the flywheel bolts (1) with a vertical line.
Tighten all flywheel bolts (1) with an angle of rotation of 45° using the special tool 00 9 120 .
Remove special tool 11 9 811 /11 9 265 .
1Vnbzjo3he
1VnYIr6cwY
Tighten flywheel bolts (adhere to angle of rotation in the next work step).
1Vnh31c7GO
21 21 500Removing and installing or replacing clutch (SAC 240)
1MG7fLt
Special tools required:
1RjtPvO Important!
Do not clean the self-adjusting clutch and flywheel with high pressure cleaner or a washing machine, as the proper function of the adjustment unit and damping springs can then no longer be guaranteed.
Clean friction surface only.
Check self-adjusting clutch for wear and damage and replace if necessary.
1Ly5z2h Necessary preliminary tasks:
F5iQBFo Identification of self-adjusting clutch ∅ 240 mm:
  • 3 openings each with a pressure piece (1) of adjustment ring and a pressure spring (2)
Note:
Figure shows new position of the thrust pieces.
1VnXQFZYDa Removal:
1VnYR2rsi7 Lock flywheel with special tool  11 9 260 .
1VnYWJadvT Insert special tool 21 2 180 in self-adjusting clutch.Note:
Locking hooks (1) of special tool 21 2 180 must engage in recesses of self-adjusting clutch.
1VnYSSPPXA
Press special tool 21 2 180 together at handles (2) until limit position and grip firmly.
At same time tighten down knurled screws (1).
Adjusting ring of self-adjusting clutch is now secured.
1VnYc6voHY Fit special tool 21 2 170 with the pressure plate 2 288 165 and tighten down at knurled screw (1).
1VnYcViVv7 Screw in spindle (1) until diaphragm spring (2) is tensioned up to stop.
1VnYTw3YnK Unfasten the bolts and remove the self-adjusting clutch from the flywheel.Important!
Do not use a special tool to detach the self-adjusting clutch from the flywheel.
Installation note:
Screws must be replaced.
Jointing torque and angle of rotation must be observed without fail.
A4u0UoN
Remove clutch disc (1) from flywheel.
Clean flywheel, check for wear and damage.
Replace damaged flywheel.
Check grooved ball bearing in crankshaft for ease of movement and tightness and if necessary replace grooved ball bearing.
1RjtPvO Important!
Always replace clutch discs fouled e.g. by oil, cleaning agent.
Check the clutch disc for damage and frictional corrosion in the hub profile and replace if necessary.
1VnYZf81fp
Check clutch disc for wear:
Measure lining protrusion at lining rivets at closing head (A) in each case.
Note:
Rivet connection
a) Closing head
b) Swage head
Replace clutch disc if lining protrusion at closing head (A) is less than 1 mm.
Push clutch disk onto the cleaned transmission input shaft and check for easy movability.
1RjtPvO Important!
Check self-adjusting clutch for wear and damage and replace as necessary.
1Jvu2xy Reinstall the previously removed self-adjusting clutch and clutch disc:
1RjtPvO Important!
Handle clutch disk carefully, do not touch surfaces of friction pads.
Clean friction surfaces of the flywheel and the pressure plate with BMW-approved brake cleaner.
Install clutch disc in correct position.
Note designation for ”engine side” / ”transmission side”.
1VnYUzN90i Centre clutch disc (1) with special tool 21 2 230 .
Special tool Transmission
21 2 230 GS6-45 BZ/DZ
1VnYdM48TT
Mount self-adjusting clutch (1) on flywheel together with special tools.
Pay attention to dowel pins (2).
Self-adjusting clutch (1) must be secured by way of dowel pins (2).
Install and tighten down screws.
Tightening torque: 21 21 1AZ.
1VnYcViVv7 Release spindle (1) until load is fully removed from diaphragm spring (2).
1VnYc6voHY Release knurled screw (1) and remove special tool 21 2 170 2 288 165 using the pressure plate from self-adjusting clutch.
1VnYSSPPXA Release knurled screws (1) and remove special tool 21 2 180 from self-adjusting clutch.
1VnYUPva1J 21 2 230 Withdraw special tool from clutch disc with aid of accompanying screw (1).
1VnXMC9mOc Required reworking:
1Jvu2xy Installing the removed self-adjusting clutch along with new clutch disc:
1RjtPvO Important!
Before installing a self-adjusting clutch which has been in service with a new clutch disc: always reset adjusting ring in new position.
1RjtPvO Important!
1VnYdM48TT
Insert and tighten the mounting bolts of the self-adjusting clutch.
1Jvu2xy Installing a new self-adjusting clutch:
1RjtPvO Important!
Install clutch disc (1) in correct position.
Note designation for "engine side"/"transmission side".
The clutch operator contained in the new replacement clutch set absolutely must be installed.
1VnYQ3xP1U
Slide the self-adjusting clutch onto the dowel pins (1) in the flywheel and screw tight.
Part: Replace screws.
1RjtPvO Important!
Stop (1) may only be removed with self-adjusting clutch screw-mounted.
1VnYYOpgmf Carefully unscrew stop (1) clockwise or anticlockwise using a size 14 (2) hexagon socket wrench.Note:
A slight snapping of the plate spring while unscrewing is possible.
Mandrel
212250
Minimum set: Mechanical tools
Mechanical tool
GRSW2122-50
Note:
(clutch centring drift) For centring drive plate when installing. Clutch disc with modified gearing. Transmission: S5D 250G (B transmission)
Storage Location: A50
SI number: 01 20 04 (135)
36 minutes ago, ebay said:
11 22 Flywheel
Tightening Torques
1VnXo6cNTV
Manual gearbox.
1VnYIr6cwY
1Vnc6wsArH
Manual gearbox.
1VnXo6cNTV
1Vnh31c7GO
1Vnbzjo3he
1VnYIr6cwY
1Vnh31c7GO
1MG7fLt
1RjtPvO Important!
Note:
1VnXQFZYDa Removal:
1VnYSSPPXA
Installation note:
A4u0UoN
1RjtPvO Important!
1VnYZf81fp
Note:
Rivet connection
a) Closing head
b) Swage head
1RjtPvO Important!
1RjtPvO Important!
1VnYdM48TT
1RjtPvO Important!
1RjtPvO Important!
1VnYdM48TT
1RjtPvO Important!
1VnYQ3xP1U
1RjtPvO Important!
Mandrel
212250
Mechanical tool
GRSW2122-50
Note:
Mare om🫡
Si cuplu strangere ambreiaj?😁
40 minutes ago, Sorin_87 said:
Eu vad doar tabelul cu volantul.
Orice link(cod piesa, tabel, etc) ma duce catre site-ul newtis, care e inchis.
Mersi.
Dacă nu ai cont,nu poți sa vezi ce cupluri sunt,de aia ți am și scris la volant și ambreiaj.
Dacă nu știe mecanicul cuplurile e cam nasol,sa le stranga aiurea așa...
Mersi.
21 21 Clutch Disc and Drive Plate
Tightening Torques
  Type Thread Work instruction Torque
1AZ Clutch to flywheel
F06 / F10 / F11 / F12 / F13 / F18 / F20 / F21 / F22 / F23 / F25 / F26 / F30 / F31 / F32 / F33 / F34 / F36 / F80 / F82 / F83 / F87 M8 10.9
Renew screws.
      1. Jointing torque 15 Nm
      2. Angle of rotation 90 °
Sponsored links
