bloc de sigurante
dr.touring
10. The two knobs on the center control panel are to reset the short trip mileage and the other one is for changing the time on the clock and changing the time from army time (24 hour time) to normal time. And you could also switch the temperature display both on the dash and on the climate control between Fahrenheit and Celsius.
Dar daca nu ai butonul de BC, tot degeaba. Verifica pe la mica publicitate, parca vindea cineva o maneta cu BC.
Da,ai dreptate ,dar cum se face asta?
293324[/snapback]
cu vreo 200 ron la ab (piese si manopera); daca iei doar maneta cu comanda BC mai ai nevoie de un set de cabluri si senzorul de temp exterioara; la ab vine kitul intreg ca part number.
293331[/snapback]
cred ca are senz de temperatura deja ...
cel putin la mine asa a fost ...eu am e46 fara facelift ...
daca iei maneta de la dorin iesi super ieftin ...eu am luat de la Filaret dracia
