Diferenta intre nr km si km ramasi pt schimb ulei
bog 325
Am observat o diferenta in km afisati in bord (rulati) in momentul efectuarii schimbului de ulei si counter-ul de "oil service". La mine oil service e setat la 25000 km si acum e aprope de 0. Computerul masinii ar trebui sa -mi arate cu 25000 km mai mult dar de fapt arata numai cu 20000 - unde sint cei 5000 km pe care ia inregistrat "oil service counter" - aproximeaza si transforma durata de timp cit masina a stat la relanti sau e vreo eroare ceva?
307814[/snapback]
nu! teoretic ai un senzor care citeste aciditatatea uleiului.... si care iti spune cand trebuie schimbat, in functie de cum mergi ...( daca ii dai "talpa" sau nu) :blink:
307826[/snapback]
Aciditatea uleiului.... Mare gradina Lu' Dumnezeu.
Kilometri care ti-i da pt schimbul de ulei nu sunt invartiti la roata; e vorba de orele si regimul de functionare. S-a mai discutat pe forum.
Ai dreptate.
Se tine cont numai de regimul de mers, nu exista nici un senzor:
While conventional systems rely on milage alone to determine when service
is due, the BMW Maintenance System reflects the actual conditions under which the vehicle is operated: some miles are more strenuous than others. From a maintenance point of view, 62,000 miles (100,000 km) accumulated in short-distance urban driving are not the equivalent of the same distance covered at moderate cruising speeds in
long-distance highway travel. The BMW Maintenance System monitors actual operating conditions as the basis for defining when the Engine Oil Service and Inspections I and II are due.
Edited by MaQ
