CUM RESETEZ INSPECTIA DE PE BORD
tzy77
@tzy77: http://www.bmwtips.com/tipsntricks/reset-plug/reset.htm
Daca nu ma insel, masina ta este prefacelift deci link-ul iti va fi util.
Pt. prefacelift:
1) If you have a reset tool then turn your car key to Position II but do not start the car.
2) Turn the cap counter clock wise on the Data Link Connector and insert the Reset Tool
3) Follow the instructions of your reset tool, different models may have different fuctions however they all create a short in PIN 7 to PIN 19 for a given amount of time.
# OIL Service Reset requires pin 7 and 19 to be closed for 3+ seconds
# INSPECTION Service Reset requires pin 7 and 19 to be closed for 10+ seconds
4) Once done, remove the reset tool and close the cap .
5) Your dash should light up with green lights at this point.
If the light did NOT reset after the above steps then you might be reseting Oil Service however an Inspection Service is needed.
Deci tb sa conectezi pinii 7 si 19 ai mufei din compartimentul motor.
Pentru a trece gradele din fahrenheit in celsius trebuie sa pui contactul in pozitia 1 adica accesorii, apesi butonul stang din bord si cu butonul apasat iei contactul.
Data viitoare incearca cu SEARCH, existau deja topicuri pentru aceste probleme:
http://www.bmwclub.ro/forums/index.php?sho...p;hl=fahrenheit
http://www.bmwclub.ro/forums/index.php?sho...=5634&st=20
Te rog nu mai scrie cu MAJUSCULE!
