grozadan
Am nevoie de piesa 17 (senzor de presiune) pentru masina din semnatura FM31483:
http://www.realoem.com/bmw/diagrams/o/u/123.png
Ce marca ai si cat costa? Poti sa o trimiti lui Stef (unvicont) sambata, in Italia, si-ti da el banii? Multumesc!
P.S. Te-am sunat la numarul de telefon afisat in primul post, dar nu ai raspuns.
Iarta-ma nu am mai cumparat, care e procedura de achizitie si in cat timp ajung piesele la mine (fulia si geamurile)
depinde care fulie , cea vaico pe maine , restul 2 poimaine, daca vrei sa le comanzi am nevoie de nume , adresa, nr tlf ; vezi ca pt ca fulia sa beneficieze de garantie trebuie sa schmbi si surubul care costa extra 50 lei
257 lei/facet , sau 376 lei/oe - imi ajunge doar luni , sau 337 lei meat and doria
Guest Rosoaga
Buna ziua! Am un BMW E39, anul 2001, 530D, Daca ma puteti ajuta cu urmatoarele preturi:
1.bratul 6, faÞã stânga ºi dreapta: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/front_axle/stabilizer_front/
2.Scut, sub masina care protejeaza partea faÞã: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/front_aggregate_protective_plate/
3.stânga ºi dreapta jos (aparatorile de noroi de la bara): http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/air_duct/
4.pedale: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/retrofit_m_aluminium_foot_rest/
5.Carpet: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/floor_mats_commercial/
http://www.google.ro/imgres?q=Set+of+floor+mats+Commercial+LHD+E39&um=1&hl=es&sa=N&biw=1600&bih=659&tbm=isch&tbnid=-X2LhLNC7pwuJM:&imgrefurl=http://www.m5board.com/vbulletin/m5-e60-group-buy-forum-sponsor-discussion-offerings/170880-modbargains-oem-bmw-m5-floor-mats-e60-m5-5-series.html&docid=BnpkglpciVew8M&imgurl=http://www.modbargains.com/zoom_img/_1293538084.jpg&w=400&h=291&ei=IE0PT8HRPM7gggfP5djSAw&zoom=1&iact=hc&vpx=180&vpy=313&dur=603&hovh=191&hovw=263&tx=195&ty=91&sig=109321038751684982874&page=1&tbnh=132&tbnw=182&start=0&ndsp=21&ved=1t:429,r:7,s:0
6.toate cele cinci filtre: aer, motorina, ulei, de aer 2 hab.
7.Bari M5 , cu PDC. http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/retrofit_kit_m_aerodyn_package/
8.Engine ulei: Castrol pentru turbo Dizel: 5W-40 astept oferte oferta
10.Panglica cu pixeli bord .
11.suportii care sprijinĂŁ radiator de apa (toti) ex.10: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/radiator/radiator_expansion_tank_frame/
12.garnitura 10 Âşi silicon special pentru lipit geam Far. : http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/lighting/headlight_parts_lhd/
13.fata discurile de frânã plus pastile 1.:http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/brakes/front_brake_brake_disc/
Âşi 11: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/brakes/front_wheel_brake_brake_pad_sensor/
14.spate piesa 1: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/brakes/rear_wheel_brake_brake_disc/
piesĂŁ 11: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/brakes/rear_wheel_brake_brake_pad_sensor/
15. debitmetru aer : http://www.google.ro/imgres?q=air+flow+meter+E39&um=1&hl=es&biw=1600&bih=659&tbm=isch&tbnid=bCjGL1CYQ7S4KM:&imgrefurl=http://www.expressauto24.net/Mass-Air-Flow-Sensor-0280217533-BMW-E39-535i-M5-E38-735i-iL-Z8-49&docid=leaedjquvueO2M&imgurl=http://www.expressauto24.net/WebRoot/StoreES3/Shops/eb8978/4CE5/2197/0DEF/3AAB/F293/D94C/9B1E/6BCB/t3007.jpg&w=600&h=600&ei=sVUPT7KkKoryggeIkOX1Aw&zoom=1&iact=hc&vpx=179&vpy=138&dur=504&hovh=225&hovw=225&tx=152&ty=121&sig=109321038751684982874&page=1&tbnh=143&tbnw=143&start=0&ndsp=24&ved=1t:429,r:0,s:0
16. insonorizant capota ( partea textila).
17, scaun pasager senzor, piesa 7: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/seats/front_seat_cover_pad/
18. galeriile de racire frana (toate de la bara ) ex piesa 18 : http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/m_trim_panel_bumper_front_sa715/
MulĂžumesc. transmite toate informaĂžiile Âşi recomandĂŁrile.
Eu stau stau spania pot fi trimise aici??
Te sun sambata sa vin dupa ea. Becul este OE da?
in nici un caz,oe este doar cu soclu cum ti-am ofertat initial la 100 si de lei; in weekend nu ma gasesti,maine sau luni
Salut!
Da-mi, te rog, un pret pt. canale racire etrier pt. bara M3 look si pt. M Paket, in cazul in care difera.
Am un 330 Ci e46 non facelift din 2002.
Multumesc.
pt bara m pachet de 330 Ci e46 non facelift din 2002
http://realoem.com/bmw/showparts.do?model=BN51&mospid=47620&btnr=51_3275&hg=51&fg=75 79 lei/buc,iar pt bara de m3 acelasi an
se pare ca sunt aceleasi
1.bratul 6, faţă stânga şi dreapta: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/front_axle/stabilizer_front/
105 lei/buc/lemforder sau 65 lei/buc/talosa
2.Scut, sub masina care protejeaza partea faţă: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/front_aggregate_protective_plate/ asta e scutul de metal,nu cred ca masina ta are asa ceva,dar se poate pune ar costa 635 lei dar mai ai nevoie si de bara din figura care costa inca 535 lei,scut normal de plastic adica asta http://realoem.com/bmw/showparts.do?model=DL71&mospid=47545&btnr=51_2427&hg=51&fg=75 piesa 9 din link costa 387 lei/oe;
3.stânga şi dreapta jos (aparatorile de noroi de la bara): http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/air_duct/ 55 lei/buc/oe ;
4.pedale: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/retrofit_m_aluminium_foot_rest/ ,adica suport picior M 220 lei
5.Carpet: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/floor_mats_commercial/ 530 lei/oe set sau doar sofer 235 lei dar nu cu emblema M alea nu se mai fabrica
6.toate cele cinci filtre: aer 115 mann sau 85 sct, motorina 160 mann sau 105 mahle sau 50 alco, ulei 42 mann, de aer 2 hab 210 mann sau 75 4f set ambele variante carbon.
7.Bari M5 , cu PDC. http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/vehicle_trim/retrofit_kit_m_aerodyn_package/ asta e pachet m 1000 euro cuprinde mai mult decat cele 2 bari,adica canale aer,suport numar m,grile proiector m dar nu contine tot ce trebuie,de exemplu nu contine proiectoarele ,difuzorul bara spate; doar bata fata ar costa 500 euro,bara spate 500 euro,daca le vrei pe amandoua iesi mai bine cu pachetul
8.Engine ulei: Castrol pentru turbo Dizel: 5W-40 astept oferte oferta, 27 lei/litru/oe bmw sau 160 lei/bidon de 5 l castrol si la litru 36 lei/litru
10.Panglica cu pixeli bord = cu asa ceva nu te pot ajuta
11.suportii care sprijină radiator de apa (toti) ex.10: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/radiator/radiator_expansion_tank_frame/ ,piesa 10 nu exista pe masina ta,bine pt sigutranta as avea nevoie de o serie sasiu;
piesa 6 3 lei/buc,piesa 13 36 lei,12 36 lei,11 46 lei,7 11 lei;
12.garnitura 10 şi silicon special pentru lipit geam Far. : http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/lighting/headlight_parts_lhd/ piesa 10 din linkul dat de tine e un bec ... ???? oricum da-mi o serie sasiu
la restul da-mi serie sasiu pt ca am indicii ca ori nu sunt bune linkurile,respectiv codurile din ele bune ori ai gresit ceva
13.fata discurile de frână plus pastile 1.:http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/brakes/front_brake_brake_disc/
piesă 11: http://bmwfans.info/parts/catalog/E39/Sedan/Europe/530d-M57/LHD/M/2001/april/browse/brakes/rear_wheel_brake_brake_pad_sensor/
Mulţumesc. transmite toate informaţiile şi recomandările.
Eu stau stau spania pot fi trimise aici?? DA,prin atlassib la o agentie sau gls direct la adresa
salut,preturi si explicatii in text
Edited by grozadan
Ok, atunci cred ca iau varianta cu tot cu soclu, nu ma mai complic.
As fi interesat si de stergatoare de parbriz (amandoua), pentru aceeasi masina B410713. Ceva variante...
chederul lipit de pe usa stanga spate pt e46 FL berlina...Door weatherstrip rear left 1 51348194697...asta e codul sper..un pret cu factura si tva...merci
240 lei
un debitmetru pentru un 318ci e46 din 06.2000 ( cred ca part number e 13621433565) BOSCH cat ma ajunge??
735 lei
Ah, scuza-ma ! Nu am observat. Vreau si eu o pereche. Cum sa procedez? Iti dau un PM cu datele de expeditie?
Edited by Boneaparte
