grozadan
senzor lumini - 37146778815 / 37146785207 (am gasit 2 coduri pt acelasi senzor)
amortizoare
LEFT FRONT SPRING STRUT 31306771179
RIGHT FRONT SPRING STRUT 31306771180
ADDITIONAL SHOCK ABSORBER, FRONT 31336767333
GUIDE SUPPORT 31306775098
COVERING CAP 31311139453
WASHER-GASKET 31306772226
DUST PROTECTION COLLAR 31331110196
FLAT WASHER 31306763966
UPPER SPRING PLATE 31336764093
SPRING PAD UPPER 31336767500
SHOCK ABSORBER, REAR 33526771729
ADDITIONAL SHOCK ABSORBER, REAR 33534035353
HEX NUT WIHT FLANGE 33526775726
SUPPORTING CUP 33526764418
SEALING GROMMET 33506767010
GUIDE SUPPORT, LOWER PART 33506771738
GUIDE SUPPORT, UPPER PART 33506771737
63euro
amortizoare
LEFT FRONT SPRING STRUT 31306771179 210euro sau 470lei/sachs
RIGHT FRONT SPRING STRUT 31306771180 idem
ADDITIONAL SHOCK ABSORBER, FRONT 31336767333 12 euro
GUIDE SUPPORT 31306775098 68eur sau 85lei/ruville
COVERING CAP 31311139453 1.1 euro
WASHER-GASKET 31306772226 1euro
DUST PROTECTION COLLAR 31331110196 1.5 euro
FLAT WASHER 31306763966 3euro
UPPER SPRING PLATE 31336764093 9eour
SPRING PAD UPPER 31336767500 1.5 euro
SHOCK ABSORBER, REAR 33526771729 118eur/buc/orig sau 300lei/sachs
ADDITIONAL SHOCK ABSORBER, REAR 33534035353 13 eur
HEX NUT WIHT FLANGE 33526775726 0.7eur
SUPPORTING CUP 33526764418 2eur
SEALING GROMMET 33506767010 1eur
GUIDE SUPPORT, LOWER PART 33506771738 6.5eur
GUIDE SUPPORT, UPPER PART 33506771737 8 eur
ai preturile in text;pt arcuri 85 euro/bucata/original pt pachet m sau sport
pentru un 320D E46 din 2000, te rog preturi pe original si producator la
05 THERMOSTAT WITH ADAPTER 11532247019 54euro/original;ce am pe prod e la acesi pret sau mai scump
06 PROFILE-GASKET 11532247022 5 euro
si 81229407454 antigel original 36lei/1.5 litri
multumesc !
ai preturile in text mai sus
salut,
pt un 320D (e90) serie sasiu ku49100, ma intereseaza preturi la:
set amortizoare sport (+ ce mai trebuie la schimbarea lor, bucsi, etc)
set arcuri
senzor reglaj faruri
merci
da-mi coduri mai putin pt arcuri ca nu ai unde sa le gasesti
la termostat, garnitura si antigel, preturile sunt in euro contin tva?
multumesc !
Pt e 39 2003 525 d vin gy 14774
- filtru motorina
- filtru ulei
- filtre polen
- filtru aer
- ulei cutie orig Bmw (daca este sau ce ai pe producator)
- discuri frana/ placute ATE (de preferat) fata/spate + senzori de placute
- bujii incandescente Bosch
modalitatea de plata si transport.
Cu stima ,
Marcel
- filtru motorina 145 bosch sau 100 champion
- filtru ulei 37/mann sau 20 lei/champion
- filtre polen 100lei cu carbon
- filtru aer bosch 130lei
- ulei cutie orig Bmw (daca este sau ce ai pe producator)-
- discuri frana/ placute ATE (de preferat) fata/spate + senzori de placute;senzor 42lei/spate+42/fata
disc fata 82eur/original/buc,trw 225/buc,brembo 230,bosch 250,370lei set de 2 /delphi;250/buc/ate
disc spate 230/buc/ate;210/delphi set de 2;74 eur/buc/original
280lei placute fata ate;110 eur/original sau 100lei/qwp
spate placute 80 eur/orig;160/ate sau 120/delphi
Cu stima ,
Marcel
modalitatea de plata si transportul vin la tine sau vi la mine ca esti la 500 metri:))
bujiile raman la acelasi pret cat ti-am dat atunci (55 lei/buc-inca nu le-am dat inapoi)
pt restul ai preturile incluse in textul tau;cred ca ti-am dat din ce sa alegi:)
Cu stima ,
Marcel
de data asta S-AR putea sa le trimiti unui prieten la bucuresti.
Cu bujiile te sun luni dimineata sa ne intalnim sa mi le dai.cu eletromotorul de ford am rezolvat-o numai curatandul.
merci oricum Dan
te salut
Cu stima ,
Marcel
pt uleiul din cutie se poate dar am nevoie de niste numere de pe cutie;sa ia ce scrie acolo pe cutie;cu seria sasiu nu faci nimic..
51462268848 - polita portbagaj e36 compact-cel mai ieftin care ai .ar fi de preferat de la producator dak gasesti ca e mai ieftin ca original
nu exista asa ceva pe producator;190 euro e pe original/nou
cat costa 2 bascule complete (pivot + bucse) pt E 46 316 din 2000 de 1.9L ?
1340lei/producator delphi
fata si spate /discuri de frana + placute KS70452, si inca o intrebare, momentan am pe spate discuri normale nu ventilate, se poate face conversia fara sa mai schimb ceva ?
290lei set de 2 disc/delphi;195lei/buc/ate;
240/buc/spate/ate sau 340lei set de 2 /delphi ventilate-poti sa faci conversia fara sa schimbi si altceva(parerea mea)
nu se poate face conversia doar schimband discurile ,nu iti intra .trebuie sa schimbi si suportul de etrier.
