ajutor e 46
cris
AM O PROBLEMA CU BMW ,E 46 318,BENZINA ,1999,SI NU REUSESC SA II DAU DE CAP.AM SCHIMBAT BATERIA ACUM 2 LUNI,ESTE NOUA,DAR NU VREA SA MAI PORNEASCA.ARE SIMPTOMELE CA ATUNCI CAND ESTE BATERIA PRAF,CAND DAI LA AUTOMAT SE APRIND FARURILE SI NU VREA SA PORNESCA.AM INTELES CA SUNT BORNELE OXIDATE,LE-AM CURATAT BINE SI TOT DEGEABA.IERI AM PORNITO CU CABLURI DE LA ALTA BATERIE,A MERS 15 MINUTE,AM OPRITO SI AZI NU A MAI VRUT SA PORNEASCA,ACELEASI SIMPTOME.CE POT FACE,CE ARE?VA MULTUMESC MULT SI ASTEPT SOLUTIILE VOASTRE. :blink: :) :)
VA MULTUMESC FOARTE MULT PENTRU SFATURI,DAR ALTERNATORUL NU ESTE CA AM FOST LA ELECTRICIAN SI INCARCA FARA PROBLEME,BORNELE SUNT CURATATE DE IERI SI FOARTE BINE STRANSE,ACUM AM PUS O ALTA BATERIE PE MASINA SI ASTEPT PANA MAINE DIMINEATA SA VAD DACA ARE ACELASI SIMPTOM,CA ACUM PORNESTE FARA PROBLEME,SI AM PRIMIT SFATUL ELECTRICIANULUI SA PUN BATERIA PE REDRESOR O NOAPTE MACAR,CEEA CE AM SI FACUT.CABLUL DE LA PLUS ESTE OK,NU ARE DELOC JOC,DAR NU STIU UNDE POT GASI UN TESTER SA IMI ZICA UNDE ARE SCURGEREA DE CURENT.DACA AVETI SFATURI LE ASTEPT CU INTERES.POATE SE MAI INTAMPLA ACELASI SIMPTOM SI LA ALTCINEVA CA DOAR NU O FII UN SIMPTOM NECUNOSCUT.
si eu spun la fel...sa o duci pe un tester,parerea lui e cea mai importanta...pe undeva sigur pierde curent sau daca nu e bateria naspa!chiar daca e noua nu este exclus sa fie praf!
daca ai luat-o de la unu care plimba baterii intr-o sacosa cu bicicleta(cum se mai intampla pe la noi) atunci e naspa sigur!
AM SCHIMBAT BATERIA SI ACUM PORNESTE FARA PROBLEME,NU CREDEAM CA O BATERIE VARTA CUMPARATA DIN METRO SA MOARA DUPA 3 LUNI DEJA.MAI BINE CUMPARAM UN JEG DE CARANDA CU JUMATATE DE PRET FATA DE VARTA SI TOT MA TINEA 2 ANI.VA MULTUMESC FOARTE MULT DE SFATURI. :) :) :)
banuiesc ca ai luat-o cu tot cu garantie :D
AVEA GARANTIE DAR TREBUIA SA O FAC LA INCEPUTUL LUNII IANUARIE SI AM COMISO ,MI-AM RUPT PICIORUL LA SCHII SI NU AM AJUNS CU EA IN 7 ZILE LA GARANTIE,ASA CA ACUM ESTE PE ALTA MASINA,MASINA DE FIRMA CARE MERGE NON STOP SI ACUM NU MAI FACE DEOCAMDATA FIGURI,PLUS CA A STAT O NOAPTE PE REDRESOR.MERCY PENTRU SFATURI.
