Consum instant pe X3
Courage
Am gasit asta pe net. Inca nu am ajuns sa verific.
X3 nu arata consumul instant si este frustrant.
Well, the instant fuel consumption reading while idling is never accurate because when you are not moving, you are infinitely consuming fuel. The instant fuel consumption simply shows 30l/100km as a base reading when you are stopped.
To view instant consumption, you may dive into the hidden on-board computer functions. Start with the vehicle off, key out.
1. With your left hand, hold the S/R button in the instrument panel, while turning the key to position 1. The OBC will read "test __"
2. At this point, keep pushing the S/R button until you reach "19._". Then, it will alternate between on and off. When it shows off, push the S/R button until it shows "4._"
3. After a second or so, it should show "4.0 _ _ _ _ _ ". You may start the vehicle at this point. Numbers should show up in the blanks as you accelerate. This is instant fuel consumption. "136" translates to 13.6 l/100km. Note that with a cold engine, fuel consumption is substantially higher.
La varianta de deblocare, dupa ce dadeai pe 19, iti cerea sa bagi un cod, care era suma cifrelor datei curente, dupa ce o introduceai, iti scria FREI, si puteai accesa toate functiile. Nu stiu cum e la X3. Asta e valabil la E32/E34/E39/E38.
Or mai fi evoluat BMW-urile de atat timp, dar cel putin pe vremuri se facea asa:
The OBC knows two modes: Locked and Unlocked.
When you get your car, it's probably locked. In the locked mode, the hidden functions will refuse to work.
In the unlocked (free) mode, the hidden functions can be accessed.
Please be carefull to use these functions, especially function 21: This one resets all OBC data !
To change the lock/unlock mode, you have to execute function 19, see the table on this page. Example: On 13 march, you would have to add 13 and 3, giving 16.
http://home.iae.nl/users/bts/obc.htm
La E39 aparent nu mai trebuie sa introduci data:
http://www.ideaphile.com/bmw/540-obc.html
