"check brakes lining" ?
culmea e ca placutele le-am schimbat fix cu o zi inainte sa plec.
deci nu au decat 9 zile pe masina.
o sa o duc la service...
dar inainte de asta voiam sa vad ce puteti voi sa imi spuneti, ca sa nu ma trezesc ca am de cumparat o masina noua. :)
ieri am facut 1000km cu becul ala rosu aprins si nu am avut nici o problema.
doar o profunda emotzie la inceput.. ca aveam 170 kmh :blink:
M.
Edited by mixxed
Ai dreptate.. m-am uitat in dictionar. Ce chestie.. Eu stiam ca lining inseamna garnitura, dublura...
Dar:
brake lining
a material of asbestos, minerals, fine wire, etc. riveted or bonded to a brake band or shoe to create the friction necessary for braking
©1995 Zane Publishing, Inc. ©1994, 1991, 1988 Simon & Schuster, Inc.
:blink: sorry.
M.
48733[/snapback]
Probabil ca e o problema de la senzor se mai intampla,cel mai probabil o sa-ti reseteze computerul la service.
Dupa manual:
"CHECK BRAKE LININGS: Have the brake pads inspected by your BMW center." :blink:
"Brake system
Brake fluid level
The warning lamp for the brake hydraulic system comes on, or the "CHECK BRAKE FLUID" message appears in the Check
Control. The brake fluid level is too low in the
reservoir.
If the brake fluid level is too low and brake pedal travel has become noticeably longer, there may be a defect in one of the brake system's hydraulic circuits. Proceed to the nearest authorized BMW center. Higher brake application pressure may be necessary under these conditions, and brake pedal travel may be significantly longer. Please remember to adapt your driving style accordingly. The warning lamp comes on together with the "CHECK BRAKE PADS" message
in the Check Control."
Deci mai probabil lichidul decat palcutele, daca zici ca tocmai le-ai schimbat.
Atunci cand pui placute noi, pistonasele etrierelor trebuie impinse in etriere, deci nivelul lichidului de frana in rezervor creste. De aceea tind sa cred ca senzorul de la placute este cea mai probabila cauza. Evident, asta nu exclude posibilitatea unei pierderi de lichid de frana.
O simpla verificare lamureste lucrurile.
lume greseala nu are cum sa fie lichidul de frana
daca nu avea lichid de frana masina nu mai avea ambreaj si abia apoi ramanea fara pedala de frana
mai mult ca sigur cand a schimbat placutele nu a schimbat si senzorii de frana iar acestia deteriorati dau aceasta avarie pe bord.
Edited by SORIN TSO
E clar de la placute. De fapt placutele n-au nimic, unul din senzori trimite date eronat. De fapt nu trimite, ci are circuitul intrerupt. Ori nu au prins bine mufa de la senzor si aceasta s-a desprins (mi-e greu sa cred, daca nu prinzi mufele bine nu intra in cutiuta aceea de plastic), ori cei de la service au pus senzorul invers :blink:. Mi-e greu sa cred si asta, dar daca se forteaza vreunul, chiar poate reusi.
Ar mai fi o explicatie: i-au facturat schimbul de placute dar nu a fost facut. Sau i-au schimbat placutele si i-au pus un senzor prost. De fapt, cand ai schimbat placutele? Cand ti-a aparut mesaj in bord? Ca in momentul in care iti apare mesajul in bord, senzorul nu mai poate fi reutilizat - are circuitul intrerupt si gata. Eu in lipsa de senzor si in graba am pus doar o mufa cu firele legate intre ele si gata. S-a stins indicatorul din bord - dar trebuie sa le inspectez eu din cand in cand.
