resetare intervale service
Imi aparea pe bord notificare ca trebuie sa schimb bujiile. Am facut schimbul la un service oarecare si nu au stiut sa imi reseteze si calculatorul. Asa ca am cautat pe net si mi-am resetat singur. Merge pentru toate chestiile din service info(filtre, placute,etc.) Cam astia ar fi pasii:
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
  • 8 months later...
Resetare intervale service E87 dar valabil si pt. E90, E91, E92, E93
- Press and hold the trip meter reset button for approx. 10 seconds until the 1st maintenance service appears
in the LCD display.
- Select the maintenance operation required with the rocker switch on the turn-signal/main-beam switch.
- To reset, press the on-board computer button on the turn-signal/main-beam switch until the word "RESET"
appears.
- The reset is effected by pressing and holding the on-board computer button.
- During the reset, a clock will appear in the display.
- When the reset has been successfully completed, a tick will appear behind the word "RESET".
  • 2 years later...
doar ce am schimbat placutele fata azi la un service relativ de incredere si cand am ajuns acasa am observat ca au "omis" sa reseteze intervalul de service. pe-acasa am cautat pe net si am reusit sa resetez, totul a fost ok, doar ca imi arata 100.000 km acum.
Cand am schimbat placutele spate (la alt service), mi-au resetat ei indicatorul si tin minte ca atunci imi arata ca mai sunt 33.000 km. De unde aceasta diferenta? Presupun ca atunci cand au resetat ei au folosit aceeasi procedura "manuala". Se va autoregla la o valoare mai realista acel numar dupa ce se mai aduna niste km? Chiar e pe bune sau va trebui sa tin cont de uzura fizica si sa nu ma mai iau dupa ce indica masina?
La fiecare schimb am pus si senzori noi.
Salut
ce ce service ai schimbat placutele.De care ai pus?de unde le-ai cumparat?cat a costat manopera?
Merci
Si la mine imi aparuse inspection now 06.2011. Am umblat eu sa resetez...si nu mergea....si am dat la placute spate sa resetez, si dupa reset imi apare -25.000. Initial aveam 35.000, Placutele le-am schimbat acum 2 luni, senzorul nu a fost schimbat pt ca placutele mai aveau , iar senzorul nu se aprinsese. Am mers asa , a fost totul ok, De ce oare s-a aprins acum ? placutele sunt noi...nu trebuia sa umblu eu acolo sa resetez?
Am reusit la final sa resetez acea inspectie din i drive, a setat alta luna, insa cand pornesc masina tot scrie service overdue, si arata masina aceea ridicata si la idrive zice eroare cu brake pads...
Si a ramas aprins in bord si semnul exclamarii...:bye::bye:
Edited by jonnyy_b
Vezi ca trebuie schimbati senzorii, chiar daca mai aveau placutele. Asa a fost si la mine. Senzorii sunt stanga fata si dreapta spate, parca 13 euro. La mine pana nu i-am schimbat, tot ca la tine facea.
Are cineva idee de ce intervalul de schimb al placutelor fata nu mi se modifica? Cand am luat masina indica 80,000km, apoi a crescut la 90,000 si de aproape 8000km sta nemiscat acolo. Intervalul pt placutele spate se decrementeaza, insa asta ramane fix.
si eu am aceeasi "problema", de cand am schimbat placutele fata cu senzor cu tot (prin primavara) imi afiseaza tot 100.000 de km si nu vrea sa scada deloc. Dar nici pe spate nu prea imi scade, de cand le-am schimbat acum vreo 3 ani mi-a scazut de la 33.000 la 27.000 km iar eu am facut cam dublu cel putin cu masina...
