CSL
Romulus
Adaptand Istoria BMW publicata la noi pe sit, am vazut si eu in sfarsit ce inseamna CSL, Coupe Sport superLight, oricum cred ca vine din ceva asemanator in limba germana dar nu am avut rabdare sa caut, necitind germana, in documentatia germana.
Ce o fi insemnand GTR sau CSi. CSi probabil e coupe sport si 'i' vine de la benzina. Nu?
Istoria BMW
  • 5 months later...
BMW Technical Acronyms
A - processed vehicle speed signal
A - "out" (Aus)
AB - Airbag
ABL - Brake system warning Lamp (2 color)
ABS - Anti-lock Braking System
AC - Air Conditioning (from ETK)
ACC - Active Cruise Control
ACS - Active Comfort Seats
ADB(X) - Automatic Differential Braking
ADS - engine intake air control
ADV - windshield wiper pressure control
AEGS - Automatic Electronic Gearbox Control (also EGS)
AFM - Air Flow Meter
AGD - suction silencer (from ETK)
AGR - emission reduction
AGS - Adaptive transmission control
AG - Automatic Gearbox (transmission)
AHK - Active rear-axle Kinematics
AHK - trailer hitch (from ETK)
AHM - trailer Module (not for US models)
AHPS - Advanced HPS
AIC - Automatic Interval Control (rain sensor)
AKF - activated carbon canister (from ETK)
AKS - Active head restraint
AKS - pressure regulating device (from ETK)
ALC - Automatic Light Control
ALR - Automatic Lamp Range Adjustment
AMM - Air Mass Meter
AMP - radio system AMPlifier
ARI - car radio information system (from ETK)
ARS - Active Roll Stabilization
ASC - All Season traction
ASC-EZA - ASC w/ engine timing and injection intervention
ASC+T - ASC+ Traction control
ASK - Audio System controller (Kontroller)
ASR - self starter block relay (from ETK)
AST - Automatic Slip control (marketing term)
AT - remanufactured part (from ETK)
AT - Antenna (from ETK)
ATF - Automatic Transmission Fluid (from ETK)
ATL - exhaust gas turbo charger (from ETK)
AUC - Automatic air recirculation
AUT - AUTomatic transmission (from ETK)
AVT - Antenna amplifier Tuner
AZD - tightening torque specifications (in TIS)
A/D – Analog/Digital
B - Benzene (gasoline)
BAT - BATtery (from ETK)
BC - Board Computer
BC1 - Body Controller 1
BL - Brake Light (from ETK)
BLS - Brake Light Switch
BMBT - Board Monitor
BS - Block diagram
BST - Battery Safety Terminal
BVA - Brake pad wear indicator (from ETK)
BZM - center console control center
BZMF - center console control center, rear
CAN – Controller Area Network (Multiple ECU Controller)
CAN-Bus - Controller Area Network (bus)
CANH-Bus - CAN bus, High
CANL-Bus - CAN bus, Low
CANP - fuel tank ventilation valve
CAS - Car Access System
CBC - Corner Braking Control
CBS - Condition Based Service
CCM - Check Control Module
CD - Control Display
CDC - Compact Disk Changer
CDS - CD player (from ETK)
CEL - CELsius (from ETK)
CIM - Chassis Integration Module
CO - Carbon monOxide (from ETK)
COMBI – Electronic Instrument Cluster
CON - CONtroller
CU - Copper (from ETK)
CVM - Convertible top Module
CVT - Constantly Variable Transmission
CW - drag coefficient (from ETK)
D1 - Xenon light/ gas discharge (from ETK)
D-Bus - Diagnosis bus (same as TXD)
DBC - Dynamic Brake Control
DBS - Dynamic Braking System
DCS - Dealer Communication System
DE – Diagnostic Unit
DD - Dynamic motor Drive
DDE - Digital Diesel Electronics
DIN - German industrial standards
DIS - Diagnosis and Information System
DISA - Differential air intake control
DIVA - continuously variable length intake runners
DK - throttle housing/valve
DKB - throttle w/ brake intervention
DKE – Throttle Increase
DKI - throttle position
DKR - throttle reduction
DKT - throttle position signal
DKV - preset throttle position value
DME - Digital Motor Electronics
DM-TL - Diagnostic Module Tank Leakage
DOHC - Double Over Head Camshafts (from ETK)
DS - gasket set (from ETK)
DSC - Dynamic Stability Control
DSP - Digital Sound Processing
DTC - Diagnostic Trouble Code (SAE)
DTC - Dynamic Traction Control
DWA - theft deterrent system
DWS - tire pressure Warning System
DZM - revolution counter (from ETK)
E - "in" (Ein)
EBA - installation instructions (from ETK)
EBV - Electronic Brake force proportioning
ECE - European market version (from ETK)
ECM - Engine Control Module (SAE term)
ECU - Electronic Control Unit
EDC - Electronic Damper Control (from ETK)
EDR - Electronic throttle control
E-KAT - Electrically heated catalytic converter
EZA - see ASC-EZA
ECO - Controller for I-Drive system
EDC - Electronic Dampening Control
EDC-K - Electronic Dampening Control - Continuous
EDK - Electronic throttle valve
EDS - pressure regulator
EFH - Electric window lifter (from ETK)
EGS - Electronic transmission control
EH - Electronic-Hydraulic
EHC - Electronic Height Control
EKM - Electronic body Module
EKP - Electric fuel Pump
ELV - Electronic steering lock
EM - Electro-Mechanical
EMF - Electro-Mechanical parking brake
EML - Electronic Motor Load regulation
EMV - Electro-Magnetic sensitivity (from ETK)
EO - component location
EPC - Electronic Parts Catalog (also ETK)
EPROM - Erasable/ Programmable chip Memory (from ETK)
ETK - Electronic parts catalog (also EPC)
ETM - Electrical Troubleshooting Manual
ESS - Electronic anti-theft device
EV - injection Valve
EWS - Electronic drive-away protection
FB - Function description
FBC - Fading Brake Control
FBD - remote control services
FBZV - radio frequency locking system
FGR – Vehicle Speed Control (Cruise Control)
FH - window lifter
FHK - rear Heater/ air conditioner
FLC - automatic Light Control
FRU - Flat Rate Unit
FS – Crash Sensor
FZV - central lock receiver
GAL - speed dependent sound volume
GM - General Module
GMR - yaw moment control
GPS - Global Positioning System
GRII - cruise control
GRS - rotation Rate Sensor
GS – Belt Tensioner
GWK - torque converter lock-up control
H - "rear" (Hinten)
H2 - Xenon headlights
HA - rear Axle (from ETK)
HC – Hydro Carbon
HD - Heavy Duty (from ETK)
HDC - Hill Decent Control
HFM - Hot Film air mass Meter
HG - manual Gearbox (transmission)
HKL - Hydraulic trunk lid Lift
HLM – Hot Wire Air Mass Meter
HPS - Head Protection System
HR - Heater control (from ETK)
HVA - Hydraulic Valve Adjuster (from ETK)
Hz – Hertz (Cycle)
I-Bus - Information bus
IB - Interior lighting control signal
IHKA - automatic Heating and A/C
IHKAF - IHKA w/ micro filter
IHKR - regulated Heating and A/C
IHKRF - IHKR w/ micro filter
IHKS - standard Heating and A/C
IHPD - Internal High Pressure Deformation
IHR - Integrated Heater control (from ETK)
IKE - Instrument cluster Electronics
ILH - Interior Lighting, rear
ILV - Interior Lighting, front
IMS - Instant Mobility System (from ETK)
IR – Infrared
IRS – Infrared Locking System
ISC – Idle Speed Control
ISIS - Intelligent Safety Integration System
ISN - Individual Serial Number
ISOFIX - standardized mounts for child restraints
ITS - head airbag assembly/ Inflatable Tubular Structure
IVM - Integrated power supply Module
K-Bus - body bus (Karosserie)
KAT - catalytic converter
KATON - converter creating (signal)
KD - Kick-Down
KHI - interface for headphones
KL - terminal designation
KL15 - run bus (ignition switch run position)
KL30 - battery bus (hot at all times)
KL31 - ground bus (chassis ground)
KL50 - start bus (ignition start position)
KLR - accessory bus
KO - compressor "on" signal
KOMBI - instrument cluster
KOREL - compressor relay signal
KR – Contact Ring
KSK - Knock Sensor
KVA - fuel consumption signal/value
KW - crankshaft
KW - KiloWatt (from ETK)
LCM - Lamp Check Module
LDP - Leak Diagnosis Pump
LEV - Low Emissions Vehicle
LEW - Lateral acceleration sensor
LHD - Left-Hand Drive (from ETK)
LKM - Lamp control Module
LL - closed throttle
LM - Light Module
LMM - air flow meter/sensor
LMR - Light alloy wheel
LRA - vertical headlight aiming
LSM - steering column memory
LSZ - Lamp Switching center
LVA - air supply system (for EHC system)
LWR - vertical headlight aim control
LWS-5 - steering angle sensor
M-Bus - IHKA/IHKR stepper motor bus
MAL - center armrest
MBC - Maximum Brake Control
MDK - Motorized throttle valve/system
MFL - Multi-Function steering wheel
MFC - Multi-Function Controller
MFU - Multi-Function Clock
MID - Multi-Information Display
MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp
MIR - Multi-Information Radio
MMC - Multi-Media Changer
MoDiC - Mobile Diagnostic Computer
MOST-Bus - Media Oriented System Transport bus
MRS - Multiple Restraint System
MSR - engine drag torque Regulation
MV - Magnetic Valve (solenoid Valve)
n-ab - rotational speed, transmission (rpm)
n-mot - rotational speed, engine (rpm)
NAVI - Navigation module
NG - New Generation (as in N73 engine)
NG - tilt sensor
NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
NSD - rear muffler (from ETK)
NSL - rear fog Lamp (from ETK)
NSW - fog lamp (from ETK)
NTC - Negative Temperature Coefficient
NW - camshaft (from ETK)
OBC - On-Board Computer
OBD - On-Board Diagnosis (SAE)
P/N – Park/Neutral position
P-Bus - Periphery bus
PB - Pin assignments
PBS - Parts Bulletin System (in TIS)
PDC - Park Distance Control
PGS - Passive Go System
PM - Power Module
PP – Impact Pad
PTC - Positive Temperature Coefficient
RLS - Rain-Light Sensor
PWG - Pedal position sensor/ potentiometer
RA - Repair instructions (in TIS)
RAM – Random Access Memory
RAL - Aluminum wheels (from ETK)
RAL - standard color (from ETK)
RDC - tire pressure Control
RDS - Radio Data-broadcast System
RDW - tire pressure Warning
RHD - Right-Hand Drive (from ETK)
RM - Relay Module
ROZ - Research Octane rating/ fuel grade (from ETK)
RPA - tire puncture warning (from ETK)
RPS - Rollover Protection System
RS - Repair kit (from ETK)
RSW - back-up lamp (from ETK)
RXD - wake-up Diagnosis line
RZV - direct stationary ignition
SASL - Satellite, A-pillar left
SASR - Satellite, A-pillar right
SAV - Sport ACTIVITY Vehicle
SB - fuse assignments
SBE - Seat occupancy detector/sensor
SBFH - Seat module, passenger-side rear
SBSL - Satellite, B-pillar left
SBSR - Satellite, B-pillar right
SBT - SI techniques/ tech reference information (in TIS)
SCA - Soft Close Automatic/Actuator
SD - sliding roof (from ETK)
SD - silencer/ muffler (from ETK)
SE - Special Equipment (from ETK)
SES - voice recognition System
SFAH - Seat module, driver's side rear
SFZ - Satellite, vehicle center
SG - control unit
SGS - Seat integrated belt System
SHD - sliding/ lifting roof (from ETK)
SHD - Sunroof module (also SHDM)
SI - Service Information (in TIS)
SIA - Service Interval system (ver. I, II, III, IV, etc.)
SII - Service Interval Indicator
SIL - SILicon (from ETK)
SIM - Safety Information Module
SINE - Siren/tilt sensor
SKD - Steel sliding roof (from ETK)
SKHD - Steel sliding/ lifting roof (from ETK)
SM - Seat Module
SM/SPM - Seat/Mirror Memory
SMBF - Seat Module, passenger side
SMFA - Seat Module, driver's side
SMG - Sequential Manual Gearbox
SP - Schematic
SRA - headlight/fog light cleaning
SRS - Supplementary Restraint System
SSD - Steel sliding roof (from ETK)
SSH - Seat Satellite, rear seat
ST - connector views
Steptronic - transmission shift control
STVL - Satellite, left front door
STVR - Satellite, right front door
SVS - Speech processing System
SWR - headlamp cleaning system (from ETK)
SWZ - Special tool listings (in TIS)
SZL - Switch center, steering column
SZM - central switch center Module
TAGE - door handle Electronics
TCM - Transmission Control Module
TD - engine speed signal (ignition pulse)
TD - Technical Data (in TIS)
TE - fuel evaporation control
TEL - TELephone control unit
TEV - evaporative purge control
THZ - Tandem master cylinder (from ETK)
ti - Injector "on" Time (duration)
TIS - Technical Information System
TL - part throttle / load signal
TLEV - Transitional Low Emission Vehicle
TMBFT - door Module, passenger side
TMBFTH - door Module, passenger side rear
TMFAT - door Module, driver's side
TMFATH - door Module, driver's side rear
TP - Tandem Pump (from ETK)
TPS - Throttle Position Switch/Sensor
TR - engine speed signal (rpm)
TR - TRansistor (from ETK)
TRG - fuel level sensor (from ETK)
TRI - Technical Reference Information (also SBT)
TRS - battery isolation Switch
TSD - Torsional vibration dampener (from ETK)
TSH - door lock Heating
TSZI - Transistorized coil Ignition system (from ETK)
TU - Technical Update (as in M50tu)
TXD - Transmitting Diagnosis line
U-batt - Battery voltage
U-vers - supply voltage
UERSS - rollover bar (from ETK)
URS - rollover protection System
USIS - Ultrasonic passenger compartment Sensor
V - "front" (Vorn)
V - vehicle road speed
VA - front Axle (from ETK)
VAT - front axle support (from ETK)
VANOS - Variable camshaft timing
VEP - distributor-type injection Pump (from ETK)
VID - VIDeo module
VL - full load (wide open throttle)
VSD - front muffler (from ETK)
VVT – Valve tronic
WBG - hazard warning switch (from ETK)
WIM - Wiper control Module
WK - torque converter lock-up clutch
WSS – Wind Shield (from ETK)
WT – Valve tronic control unit
Z - "central" (Zentrum)
ZAB - ignition fade-out (reduction)
ZAE - central Airbag Electronics
ZAS - ignition starter switch (from ETK)
ZGM - central Gateway Module
ZK - cylinder head (from ETK)
ZKE - central body Electronics
ZKH - cylinder head cover (from ETK)
ZMS - dual-Mass flywheel (from ETK)
ZV - central locking system
ZS - central lock (from ETK)
ZSD - center muffler (from ETK)
ZV - central locking system (from ETK)
ZVM - central locking Module
ZWD - idle control valve
Si un dictionar tehnic :blink:
Technical dictionary / technische woordenlijst / technische worterliste:
2(4)-stroke    2(4)takt                                        Zwei- (Vier-) Takt
accelerating    optrekken                                    beschleunigen
adjusting screw    stelschroef                                  Einstellschraube
air filter    luchtfilter                                  Luftfilter
air intake    lucht inlaat                                    LufteinlaĂ
allen key    inbus sleutel                                InnensechkantschlĂźssel, ImbusschlĂźssel
allen head screw inbousbout  Innensechskantschraube, Imbusschraube
armature, rotor                      anker
axis, axle, shaft as                                              Achse
ball bearing    kogellager  Kugellager
battery  accu      Batterie
bleed(er) screw    ontluchtingsnippel                      EntlĂźftungsnippel
bleeding brakes    remmen ontluchten    Bremsen entluften
blinker light    richting aanwijzer                              Blinker
bolt  bout                                            Bolzen
box wrench    dopsleutel
brake  rem      Bremse
brake caliper    remklauw                                        Bremssattel
brake fluid    remvloeistof                                    BremsflĂźssigkeit
brake light    remlicht  Bremslicht
brake line    remleiding                                      Bremsbelag
brake master cilinder hoofdremcilinder                                Hauptbremszylinder
brake pads  remblokken                              Bemsbeläge
breaker  kontaktpunten  Unterbrecher
brush(es)                            koolborstels                                    kolenburste
brush holder                            borstelbrug
caliper  schuifmaat
camshaft    nokkenas  Nockenwelle
carburetor      carburateur  Vergasser
cardan huis    universal joint housing
centrifugal regulator centrifugaal vervroeger                      ZĂźndversteller
change gear, shift (gear)            schakelen                Schalten
clearance    speling                    Spiel
clutch  koppeling  Kupplung
clutch cable    koppelingskabel                              Kupplungszug
clutch plate    koppelingsplaat                              Kupplungsscheibe
clutch springs    koppelingsveren                              Kupplungsfedern
cog, chainwheel    tandwiel                                        Kettenrad
coil  spoel                                        Spule
combustion    verbranding                                  Verbrennung
commutator (contacts)                collector
compression stroke compressieslag                                  Verdichtungstakt
connecting rod    zuigerpen                                    Pleuel(stange)
crack  scheur                                          RiĂ
crankshaft    krukas                                          Kurbelwelle
current  stroom      Strom
cylinder    cilinder  Zylinder
cylinder wall    cilinderwand                                    Zylinderwand
detonation    ontsteking  ZĂźndung
diaphragms    membranen                                    Membranen
disc                                    schijf                    Scheibe
disc brake                              schijfrem                                    Scheibenbremse
drill  boor                                            Bohrer
drive shaft                          aandrijfas                                      Kardanwelle
drive shaft boot rubber mof over kruiskoppeling                  Kreuzgelenkbalg
exhaust pipe    uitlaat      Auspuff
exhaust valve    uitlaatklep                                  AuslaĂventil
feeler gauge    voelermaat                                      FĂźhlerlehre
fender  spatbord
field (coil)                            veld (wikkeling)
finned exhaust nut (geribbelde) uitlaatmoer                        Auspuffflansch-Schraube
float bowl    vlotter kamer                                Schwimmerkammer / Schwimmergehäuse
float      vlotter                                      Schwimmer
float needle    vlotternaald                                    Schwimmernadel
flywheel    vliegwiel                                    Schwungscheibe
footpegs    steps                                        FuĂrasten
fork  vork                                            Gabel
fork leg    vorkpoot                                        Gabelholm
fuse  zekering  Sicherung
gap  opening      Ăffnung
gas tank    benzine tank                                    Benzintank
gasket  pakking                                      Dichtung
gear puller    poelietrekker
gearbox  versnellingsbak                              Lichtmaschine
generator    dynamo                                          Getriebe
grease  vet      Fett
ground  massa      Masse
handle  handel                                          Griff
handlebar    stuur                                        Lenker
headlight    koplamp                                      Scheinwerfer
hex head screw    zeskant bout                                    Sechskantschraube
horn  claxon      Hupe
hose  slang      Schlauch
idle speed screw stationair afstelschroef                        Leerlaufschraube
ignition timing    ontstekingstijdstip                          ZĂźndzeitpunkt, ZĂźndeinstellung
intake valve    inlaatklep                                      EinlaĂventil
internal hex bolt    inbusbout                                    Imbusschraube
jet (main-)    sproeier (hoofd-)                            (Haupt)-DĂźse
koelrib  cooling rib                                  KĂźhlrippe
tight, narrow    krap                                            eng
laborious, lengthy                      omslachtig                                      arbeitsaufwendig, mĂźhsam
level  niveau                                          Niveau, HĂśhe
lever  hefboom                                      Hebel
locking pliers    griptang                                        Gripzange
lock nut    borgmoer                                        Feststellschraube
lock ring    borgring                                        Feststellring
lock spring    borgveer                                        Feststellfeder
loosen, release    losmaken  LĂśsen
luggage rack    bagagerek                                    Gepäckträger
margin, latitude speling                                      Spiel
membrane    membraan                                        Membrane
mixture regulating screw  mengsel stelschroef                          Gemischregulierschraube
nut      moer                    Mutter
muffler  demper      Dämpfer
nipple  nippel                                          Nippel
o-ring  o-ring                                          O-Ring
oil  olie      Ăl
oil dipstick    oliepijlstok                                    ĂlmeĂstab
pin, peg                                pen                                          Nadel
pilot (idle) mixure screw  stationair mengsel schroef                      Leerlauf(gemisch-)schraube
pilot jet    stationair sproeier                          LeerlaufdĂźse
piston  zuiger                                          Kolben
piston rings    zuigerveren                                  Kolbenringe
play (bearing play) speling (lager speling)                      Spiel (Lagerspiel
positive (pole)    plus      Positiv
potential    spanning  Spannung
pushrod  klepstoter                                      StĂśĂel
reamer  ruimer
relay  relais                                          Relais
remove      verwijderen  Entfernen
resistance    weerstand  Widerstand
rocker arms    tuimelaars                                      Kipphebel (Ăźber den Ventilen)
saddle, seat    zadel                                        Sattel, Sitzbank
seal  keerring                                        Dichtung
shaft drive    cardan aandrijving                              Kardanwelle
sharp  spits                                        spitz, scharf
shifter  schakelpook                                  Schalthebel
side stand    zijstandaard  Seitenständer
slackening    losdraaien  LĂśsen
spark plug    bougie      ZĂźndkerze
speedometer    snelheidsmeter                                  Tachometer
spring  veer                                            Feder
sprocket    tandwiel                                        Ritzel (das vordere Kettenrad)
stand      standaard  Ständer
start engine    startmotor  Anlasser
steering head    balhoofd                                        Lenkungslager
strain (to strain) spannen                                      Spannen
stroke      slag                                            Schlag
suspension, shock absorber  schokbreker  StoĂdämpfer
swingarm    achterbrug                                      Schwingenarm
                                        monobrug                                        Einarmschwinge
taillight    achterlicht                                  RĂźcklicht
taking down    uit elkaar halen                                auseinanderhalten
tap (to tap)    aftappen (van olie), tappen (van schroefdraad)  ablassen (Ăl), Gewindeschneiden
thread (screw thread) schroefdraad                                    Gewinde
thread end    draadeind                                    Gewindeende
throttle cable    gaskabel                                        Gaszug
throttle twist grip gashandel                                    Gasgriff
throttle stop screw stationair schroef                              Leerlauf-Anschlagschraube
tighten  vastmaken                                    anziehen
torque  aandraaien                                      Drehmoment
torque tube    cardanhuis                                      Kardanwellengehäuse
transmission    overbrenging                                    Antrieb, KraftĂźbertragung
tube  slang      Schlauch
universal joint    kruiskoppeling                                  Kreuzgelenk
vacuum piston    gasklep                                      Vergaserkolben
valve  klep                                            Ventil
valve clearance    klepspeling                                  Ventilspiel
valve cover    kleppendeksel                                Ventildeckel
valve guides    klepgeleiders                                VentilfĂźhrung
valve seat    klepzitting                                  Ventilsitz
valve springs    klepveren                                    Ventilfedern
voltage regulator spanningsregelaar    Spannungsregler
washer                                  ring
wheel  wiel      Rad
wrench  steeksleutel                                    SteckschlĂźssel
